Gzserver segmentation fault on start, running on WSL2
Hi everyone,
Whenever I run gazebo, I will get this:
Gazebo multi-robot simulator, version 9.14.0
http://gazebosim.org
[Msg] Waiting for master.
Running gzserver on its own gives:
[Msg] Publicized address: 172.25.127.110
When I run gzserver on its own,
[1] 19471 segmentation fault gzserver
I have tried with both gazebo9(came with ROS Melodic), and gozebo11(installed after removing gazebo9).
I am running Ubuntu 18.04 on WSL2, with VcXsrv for X server.
Valgrind shows this:
==1511== Process terminating with default action of signal 11 (SIGSEGV)
==1511== Access not within mapped region at address 0x4
==1511== at 0x40E86496: ??? (in /usr/lib/x86_64-linux-gnu/OGRE-1.9.0/RenderSystem_GL.so.1.9.0)
==1511== by 0x40E8AEDF: ??? (in /usr/lib/x86_64-linux-gnu/OGRE-1.9.0/RenderSystem_GL.so.1.9.0)
==1511== by 0x40EAF932: Ogre::GLRenderSystem::GLRenderSystem() (in /usr/lib/x86_64-linux-gnu/OGRE-1.9.0/RenderSystem_GL.so.1.9.0)
==1511== by 0x40EAA6E3: ??? (in /usr/lib/x86_64-linux-gnu/OGRE-1.9.0/RenderSystem_GL.so.1.9.0)
==1511== by 0x53B6A25: Ogre::Root::installPlugin(Ogre::Plugin*) (in /usr/lib/x86_64-linux-gnu/libOgreMain.so.1.9.0)
==1511== by 0x40E93799: dllStartPlugin (in /usr/lib/x86_64-linux-gnu/OGRE-1.9.0/RenderSystem_GL.so.1.9.0)
==1511== by 0x53B6C60: Ogre::Root::loadPlugin(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) (in /usr/lib/x86_64-linux-gnu/libOgreMain.so.1.9.0)
==1511== by 0x6D8ECA3: gazebo::rendering::RenderEngine::LoadPlugins() (in /usr/lib/x86_64-linux-gnu/libgazebo_rendering.so.9.14.0)
==1511== by 0x6D92BBB: gazebo::rendering::RenderEngine::Load() (in /usr/lib/x86_64-linux-gnu/libgazebo_rendering.so.9.14.0)
==1511== by 0x6D96184: gazebo::rendering::load() (in /usr/lib/x86_64-linux-gnu/libgazebo_rendering.so.9.14.0)
==1511== by 0x4E76594: gazebo::setupServer(int, char**) (in /usr/lib/x86_64-linux-gnu/libgazebo.so.9.14.0)
==1511== by 0x4E5DBA9: gazebo::Server::ParseArgs(int, char**) (in /usr/lib/x86_64-linux-gnu/libgazebo.so.9.14.0)
==1511== If you believe this happened as a result of a stack
==1511== overflow in your program's main thread (unlikely but
==1511== possible), you can try to increase the size of the
==1511== main thread stack using the --main-stacksize= flag.
==1511== The main thread stack size used in this run was 8388608.
Is there anything I could do about this?
Asked by squid on 2020-09-15 12:27:05 UTC
Did you resolve this? I'm getting a segfault in WSL when I run Gazebo also. If you resolved it, please update with the resolution.
Asked by mkhansen on 2021-01-05 12:21:23 UTC
I have same problem but it is solved refer to other community.
https://github.com/ros-visualization/rviz/issues/1522#issuecomment-651386909
"Solved the problem! with both adding LIBGL_ALWAYS_INDIRECT= to bashrc and -nowgl to VcXsrv as parameter."
Erdemhan's solution helps my problem.
Asked by darkkmj on 2021-02-01 21:43:02 UTC
