Robot slips/slides/vibrates over ground plane
Hi guys,
i have this rather annoying problem that my robot ( 4 legged walking robot ) vibrates over the ground plane. As a result it has no friction and every simulation of a step is useless. The force peaks are over 100N within a fraction of a second. Do you know any way to damp this force? I can't figure out how these force peaks occur. For the movement of the joints I use a plugin see code below. I would be grateful for any idea.
this->jointsFL[joint]->SetParam("fmax", 0, this->50.0);
this->jointsFL[joint]->SetParam("vel", 0, ((double)this->targetVelFL[joint]));
What I have tried until now:
-Interta System checked (twice)
-friction of the links increased
-damping of the joints increased
- And the Tags:
<min_depth>0.01</min_depth>
<max_vel>0</max_vel>
Asked by Lutz on 2020-09-16 18:31:20 UTC
It seems to have been a solver problem. For those with a similar problem try to increase the iterations (at least 100) of the simulation and set the SOR value below 1.0.
-> http://gazebosim.org/tutorials?tut=preset_manager&cat=physics ->http://gazebosim.org/tutorials?tut=physics_params&cat=physics "SOR?"-> https://en.wikipedia.org/wiki/Successive_over-relaxation
Asked by Lutz on 2020-10-11 14:10:35 UTC
