Creating world with multiple models
Hey!
I wish to create a simulation world with about 200 models interacting with each other in it. However, when I run it in gazebo, the real time factor is extremely slow (approx 0.03) Is there a way to improve this speed and at the same time maintain the accuracy of the physics and the collisions?
Thank you.
Asked by adheeshenoy on 2020-09-24 14:39:01 UTC
I would suggest the following to try to improve the RTF without changing the physics parameters:
- Keep all your models simple, especially your collisions! I would avoid using custom meshes as collisions, instead consider one of the shapes provided by Gazebo (i.e. Box, Cylinder, or Sphere).
- If you have models not being used, maybe consider creating a plugin to turn off their physics or use kinematic updates when outside a specific range, and to turn it back on later. For example, you can try setting the model to static.
Asked by bhej on 2020-09-25 10:17:10 UTC
@bhej Most of the models are spheres. Is there a plugin like the kind you mentioned? Or some reference that I can use?
Asked by adheeshenoy on 2020-09-29 16:03:10 UTC
