Realsense D435 in Gazebo
I am trying to simulate a Realsense D435 in Gazebo 9, running ROS Melodic in Ubuntu 18.04.
I am using the ROS Wrapper from Realsense and the plugin from here.
Importing the _d435.urdf.xacro and _d435.gazebo.xacro files into my own xacro, I should be able to use the camera in Gazebo and see several topics being published. My file is
<?xml version="1.0"?>
<robot name="realsense2_camera" xmlns:xacro="http://ros.org/wiki/xacro">
<xacro:arg name="use_nominal_extrinsics" default="false"/>
<xacro:include filename="$(find realsense2_description)/urdf/_d435.urdf.xacro" />
<xacro:include filename="$(find realsense2_description)/urdf/_d435.gazebo.xacro" />
<link name="base_link" />
<xacro:sensor_d435 parent="base_link" use_nominal_extrinsics="$(arg use_nominal_extrinsics)">
</xacro:sensor_d435>
<xacro:gazebo_d435 camera_name="camera" reference_link="camera" topics_ns="rs" depth_optical_frame="depth" color_optical_frame="color" infrared1_optical_frame="ired1" infrared2_optical_frame="ired2" >
</xacro:gazebo_d435>
</robot>
However, running like this causes Gazebo to crash at startup, while loading the plugin (at least it's after some text messages from the plugin). Looking at the _d435.gazebo.xacro file, I changed it slightly to include the gazebo reference when entering the plugin:
<robot xmlns:xacro="http://ros.org/wiki/xacro">
<xacro:macro name="gazebo_d435" params="camera_name reference_link topics_ns depth_optical_frame color_optical_frame infrared1_optical_frame infrared2_optical_frame" >
<!-- Load parameters to model's main link-->
<xacro:property name="deg_to_rad" value="0.01745329251994329577" />
<gazebo reference="${reference_link}">
<enable_wind>0</enable_wind>
<kinematic>0</kinematic>
<gravity>1</gravity>
<!--<mu>1</mu>-->
<mu2>1</mu2>
<fdir1>0 0 0</fdir1>
<!--<slip1>0</slip1>
<slip2>0</slip2>-->
<kp>1e+13</kp>
<kd>1</kd>
<!--<max_vel>0.01</max_vel>
<min_depth>0</min_depth>-->
<sensor name="${camera_name}color" type="camera">
<camera name="${camera_name}">
<horizontal_fov>${69.4*deg_to_rad}</horizontal_fov>
<width>1920</width>
<height>1080</height>
<format>RGB_INT8</format>
<far>100</far>
<noise>
<type>gaussian</type>
<mean>0.0</mean>
<stddev>0.007</stddev>
</noise>
<visualize>1</visualize>
<sensor name="${camera_name}ired1" type="camera">
<horizontal_fov>${85.2*deg_to_rad}</horizontal_fov>
<width>1280</width>
<height>720</height>
<format>L_INT8</format>
<far>100</far>
<noise>
<mean>0.0</mean>
<stddev>0.05</stddev>
</noise>
<visualize>0</visualize>
<sensor name="${camera_name}ired2" type="camera">
<width>1280</width>
<far>100</far>
<noise>
<mean>0.0</mean>
</noise>
<sensor name="${camera_name}depth" type="depth">
<width>1280</width>
<far>100</far>
<noise>
<mean>0.0</mean>
<stddev>0.100</stddev>
</noise>
<!-- </gazebo>
<gazebo reference="${reference_link}"> -->
<plugin name="${topics_ns}" filename="librealsense_gazebo_plugin.so">
<prefix>${camera_name}</prefix>
<depthUpdateRate>30.0</depthUpdateRate>
<colorUpdateRate>30.0</colorUpdateRate>
<infraredUpdateRate>30.0</infraredUpdateRate>
<depthTopicName>depth/image_raw</depthTopicName>
<depthCameraInfoTopicName>depth/camera_info</depthCameraInfoTopicName>
<colorTopicName>color/image_raw</colorTopicName>
<colorCameraInfoTopicName>color/camera_info</colorCameraInfoTopicName>
<infrared1TopicName>infra1/image_raw</infrared1TopicName>
<infrared1CameraInfoTopicName>infra1/camera_info</infrared1CameraInfoTopicName>
<infrared2TopicName>infra2/image_raw</infrared2TopicName>
<infrared2CameraInfoTopicName>infra2/camera_info</infrared2CameraInfoTopicName>
<colorOpticalframeName>${color_optical_frame}</colorOpticalframeName>
<depthOpticalframeName>${depth_optical_frame}</depthOpticalframeName>
<infrared1OpticalframeName>${infrared1_optical_frame}</infrared1OpticalframeName>
<infrared2OpticalframeName>${infrared2_optical_frame}</infrared2OpticalframeName>
<rangeMinDepth>0.2</rangeMinDepth>
<rangeMaxDepth>10.0</rangeMaxDepth>
<pointCloud>false</pointCloud>
<pointCloudTopicName>depth/points</pointCloudTopicName>
<pointCloudCutoff>0.5</pointCloudCutoff>
</xacro:macro>
</robot>
Now Gazebo runs, the camera is visible, but there are no topics being published and no indication that the plugin is being loaded. I have also tried adding the plugin under each
What am I doing wrong here? Any tips would be appreciated, any questions will be answered. Thank you!
-- EDIT 1 -- Running Gazebo with debug argument to true resulted in:
[INFO] [1601627990.163632, 0.000000]: Calling service /gazebo/spawn_urdf_model
[INFO] [1601627990.292581, 0.000000]: Spawn status: SpawnModel: Successfully spawned entity
[tcsetpgrp failed in terminal_inferior: Inappropriate ioctl for device]
[ INFO] [1601627990.532084369]: Realsense Gazebo ROS plugin loading.
RealSensePlugin: The realsense_camera plugin is attach to model realsense2_camera
Thread 54 "gzserver" received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7fff0a7fb700 (LWP 15179)]
[urdf_spawner-5] process has finished cleanly
log file: /home/cneves/.ros/log/ccfb807c-048a-11eb-80e9-40f02fe63d1c/urdf_spawner-5*.log
0x00007fff40143ff9 in gazebo::RealSensePlugin::Load(boost::shared_ptr<gazebo::physics::Model>, std::shared_ptr<sdf::Element>) ()
from /home/cneves/catkin_add/devel/lib/librealsense_gazebo_plugin.so
Asked by clusher on 2020-09-30 13:06:55 UTC
Please do check the implementation of realsense done by Neobotix for their robots
Asked by pmuthu2s on 2020-10-01 03:18:06 UTC
Thank you, they are a great resource for simulation.
However, they are using the libgazebo_ros_openni_kinect.so plugin (which is a great alternative), while I was trying to get the realsense plugin to work.
Asked by clusher on 2020-10-01 04:27:48 UTC
realsense_gazebo_plugin is a model plugin. Move it out of
and into
<gazebo>
Asked by nlamprian on 2020-10-01 15:17:56 UTC
That is what I did first, as that is the original implementation in the repository. Gazebo window opens, but hangs when starting the plugin and ends up launching a "segmentation fault".
Asked by clusher on 2020-10-01 16:43:13 UTC
Start gazebo with the debug argument to true and check the backtrace to see where it failed.
Asked by nlamprian on 2020-10-02 02:40:21 UTC
Great suggestion. I added the output to the original question. It doesn't say much, just that a SIGSEV signal was received when running the plugin.
Asked by clusher on 2020-10-02 03:43:51 UTC
Do you find the solution cause i get the same issue
Asked by alexje2k on 2022-07-09 08:59:42 UTC
