Can't fix a base in Gazebo properly
Hi people, I am trying something straight-forward, but can't seem to get it right. I try to fix a base in the world and then add another link on that base. This is the URDF code:
If I try to launch this in Gazebo, I get: Error [parser_urdf.cc:3474] Unable to call parseURDF on robot model Error [parser.cc:341] parse as old deprecated model file failed.
If I remove the base link and its joint to the "root" link, it works. Or if I remove the root link and fix the "base" link directly to "world" it works again, but again if I then try to add another link on "base", it won't work.
Asked by Jim Chai on 2020-10-05 03:18:26 UTC
Are you passing your description through xacro? You have a macro in your inertial.
Asked by nlamprian on 2020-10-06 04:51:24 UTC
Yes I am. In the end I made it work by writing all of the "world fixing" in sdf code inside
Asked by Jim Chai on 2020-10-11 08:23:36 UTC
