Porblem with URDF model and tf_tree
Hello all,
I am developing a robot from scratch. I created a urdf model (see here) and when I run $ urdf_to_graphiz Last_Mile_Robot.urdf I receive a closed kinematic chain as depicted in the following picture:
Output of urdf_to_graphiz
But strangely when I visualize the robot description model in rviz the kinematic chain is broken, I verified this also using $ rosrun rqt_tf_tree rqt_tf_tree resulting in the following output: Output of tf_tree
The "frontright" and "frontleft" links are connected to "chassis" using a continuous joint which looks like this (see code lines 165-172 & 190-197):
<joint name="front_right_hinge" type="continuous">
<parent link="chassis"/>
<child link="front_right"/>
<axis xyz="0 0 1"/>
<origin rpy="0.0 0.0 0.0" xyz="0.325 -0.325 -0.30"/>
<limit effort="0.1" velocity="0.1"/>
But when I change the type of said joints to fixed the kinematic chain is closed.
Any idea why this is happening?
Thanks in advance!
All the best, Georg
Asked by GeorgNo on 2020-10-08 07:41:28 UTC
You are missing the joint states. You can use the joint_state_publisher for testing.
Asked by nlamprian on 2020-10-08 10:18:38 UTC
