how to create gazebo world
I want to create my office Gazebo world, I have it's OGM. So it possible to create gazebo world from it. Suppose my map is accurate. Or there is any other method by which I can create Gazebo model of my office environment?
Asked by Ubuntu on 2020-10-11 23:58:11 UTC
Is your OGM 2D or 3D?
If it's 2D, you might need to touch it up with an image manipulation software (e.g. GIMP) such as scaling it to the correct size. Then you can use a CAD software (e.g. FreeCAD) to extrude it in the z direction to create a 3D model. Afterwards, you can export the 3D model as .stl
or .dae
and load it in your gazebo .world
file. A nice example can be found from amazon (https://github.com/aws-robotics/aws-robomaker-small-house-world/blob/ros1/worlds/small_house.world).
If you're OGM is already in 3D, you can probably convert it to .stl
or .dae
and use it directly. But you may need to clean it up or do some preprocessing (e.g. removing noise, inflating the points, etc.) to make it a better model
Asked by wongrufus on 2020-10-13 20:51:06 UTC
