ARIAC conveyor belt in other projects?
Hello.
I am trying to get the conveyor belt plugin from Ariac competition to work on my own project, where I need to simulate a conveyor belt moving items.
Is it possible? I have cloned the ariac data from BitBucket, added my own package in the source.
Edit
I created a simple test conveyor, but I don't see any topics popping up.
<?xml version="1.0" encoding="utf-8"?>
<robot name="conveyor_system">
<link name="frame_link">
<origin rpy="0.0 0.0 0.0" xyz="0.0 0.0 0.0"/>
<mass value="1"/>
<inertia ixx="1" ixy="0.0" ixz="0.0" iyy="1" iyz="0.0" izz="1"/>
<visual>
<origin rpy="0 0 0" xyz="0.505 0.0 0.05"/>
<box size="1.01 0.21 0.1"/>
<material name="silver">
<color rgba="0.7 0.7 0.7 1"/>
<collision>
<joint name="belt_joint" type="prismatic">
<parent link="frame_link"/>
<child link="belt_link"/>
<axis xyz="0 0 0"/>
<limit effort="1000.0" lower="-0.5" upper="0.5" velocity="0.5"/>
<origin rpy="0 0 0" xyz="0 0 0"/>
<link name="belt_link">
<mass value="1"/>
<visual>
<origin rpy="0 0 0" xyz="0.505 0.0 0.205"/>
<box size="1 0.2 0.01"/>
<material name="green">
<color rgba="0 1 0 1"/>
<collision>
<gazebo reference="belt_link">
<material>Gazebo/Green</material>
<gazebo>
<plugin filename="libRosConveyorBeltPlugin.so" name="conveyor_belt_plugin">
<robot_namespace>/tbelt</robot_namespace>
<enable_topic>/tbelt/enable</enable_topic>
<population_rate_modifier_topic>/tbelt/population/rate_modifier</population_rate_modifier_topic>
<link>belt_link</link>
<power>0</power>
<update_rate>10</update_rate>
</robot>
I would appreciate any help, I will also submit more information if needed, since I don't know what to post.
I'm also very interested in utilizing conveyor belt from ARIAC pkgs. That said, you might get better responses by asking concrete questions (otherwise I'm afraid you wouldn't get answers).
Made a edit, giving a concrete example.
