libgazebo_ros_planar_move low rotational velocity
I have a working omni-directional mobile robot in Gazebo 9/11 and ROS Melodic/Noetic. I use libgazebo_ros_planar_move to control the robot. Everything is working but when doing a rotation in place the rotational velocity is very low in Gazebo. If I for instance publish 3 rad/s to cmd_vel with RQT Robot Steering it still takes almost 30 sec to make one full rotation. Gazebo is running at 1x real-time factor, so there is no delay on that end. Is this a bug or something I am missing? I have been looking through the source of the planar move plugin, but nothing obvious here to me that should make it slow down.
Attached image shows the cmdvel sent and the returned calculated odom from the plugin in Gazebo. Odom's angular velocity caps at around 0.22, while 3.0 is sent to cmdvel. I expect both are represented in rad/s.
image description
Asked by robotlab on 2020-10-22 02:32:31 UTC
The planar move plugin works by assigning velocities directly to the model. Ie. the wheels do not move. I can only assume these commands are restricted by the friction on the wheels as they are dragged while moving. Try lowering the friction of the wheel links, and see what happens.
Asked by nlamprian on 2020-10-22 04:28:25 UTC
I will try that, but from what I understood about the planar move plugin is that it disables physics for the robot anyway, so friction parameters are disregarded hence there is no dragging of the wheels. I can basically make the robot levitate, and it would behave the same way.
Asked by robotlab on 2020-10-25 05:42:38 UTC
Additionally, the translational movement is correct moving at expected 1 m/s 🤔
Asked by robotlab on 2020-10-25 06:06:22 UTC
