animated model (actor) is invisible due to (maybe) a SSL problem
I have developed a software which can produce Gazebo scenario files automatically. The produced files call the actor module (http://gazebosim.org/tutorials?tut=actor&cat=build_robot). The files has been tested a month ago, the actor module was called successfully, I saw a walking human. When I ran these file today, the walking human disappear, but everything else is correct.
I do some test:
If I run the gazebo-11/worlds/actor.world or /actor_bvh.world, I can't see anything. The actor module is not appear, and the terminal warn:
libcurl: (35) SSL: couldn't get X509-issuer name!
So, I think my files are correct and my Gazebo has a SSL problem. How can I fix it?
Update:
I do a test today. I choose to follow the actor. The view did follow its trajectory, but I can't see the actor model.
Then I reinstall Gazebo 11. This problem is still existed.
I run the famous cafe.world (https://www.youtube.com/watch?v=nZN07_5r568&feature=emb_logo), the two actors are invisible, but everything else is correct.
When I click the actor1_plugin, the terminal warn:
Topic [/data://world/default/model/actor1/plugin/actor1plugin/jointcmd] is not valid.
Asked by Idontwan on 2020-11-09 09:24:22 UTC
