Shadow rendering problem, Ogre assertion failing
I've encountered this assertion failing when loading one of our worlds from an sdf file:
gzclient: /build/ogre-1.9-kiU5_5/ogre-1.9-1.9.0+dfsg1/OgreMain/include/OgreAxisAlignedBox.h:251: void Ogre::AxisAlignedBox::setExtents(const Ogre::Vector3&, const Ogre::Vector3&): Assertion `(min.x <= max.x && min.y <= max.y && min.z <= max.z) && "The minimum corner of the box must be less than or equal to maximum corner"' failed.
After some debugging, I realized that it's easy to reproduce:
- Launch gazebo with an empty world
- Set direction of the sun to (0, 0, -1)
It seems to be related to rendering of shadows - when I disable cast_shadow in the sdf file, the assertion doesn't fail.
Setup:
- gazebo version 11.2.0
- libogre-1.9.0v5
Has anyone experienced this? Is this a bug (or a feature)?
Asked by klebioda on 2020-11-23 07:51:42 UTC
I was not able to reproduce this in an empty world and with the given sun direction. There are a few instances of that error reported before and that's usually to do with inf pose of models, e.g.when a model falls off the ground and continue to fall to infinity, which results in an inf ogre bounding box.
Asked by iche033 on 2020-12-18 15:02:55 UTC
