Generating "legal" keyframes for moving actor
Hello Gazebo wizards!
I need some help with a gazebo plugin that generates random walk paths for a moving actor. How can I check if the generated path collides with objects in the world? It does not have to be real-time but pre-generated.
I followed the animated actor guide to set up a box that can move around in a Gazebo world.
My problem is that there are objects in the world defined in the .world file that the actor collides and goes into.
I have this function to take the current position and return a random point in its circle area.
ignition::math::Vector3d generate_nextWaypoint(ignition::math::Vector3d curr_pos){
int radius = 15;
double u = ignition::math::Rand::DblUniform();
double v = ignition::math::Rand::DblUniform();
double w = radius * sqrt(u);
double t = 2 * M_PI * v;
double x0 = w * cos(t);
double y0 = w * sin(t);
double x_new = curr_pos.X() + x0;
double y_new = curr_pos.Y() + y0;
ignition::math::Vector3d new_position = ignition::math::Vector3d(x_new, y_new, curr_pos.Z());
return new_position;
how can I do a legal check so that the positions dont overlap with an object in the world?
