ABB_robot not spawning in Gazebo although it's working in rviz correctly
I have a complicated robot it spawn correctly in rviz but when i try to have the gazebo bringUp, the robot doesn't appear:
my terminal output:
     logging to /home/beraru/.ros/log/deac11e6-3c94-11eb-aac7-9c305b2b6a57/roslaunch-beraru-22791.log
Checking log directory for disk usage. This may take a while.
Press Ctrl-C to interrupt
Deprecated: xacro tag 'sensor_d435i' w/o 'xacro:' xml namespace prefix (will be forbidden in Noetic)
when processing file: /media/beraru/CE625F5C625F47FB/reza/rviz/src/abb_robot_model/urdf/abb_robot.urdf.xacro
Use the following command to fix incorrect tag usage:
find . -iname "*.xacro" | xargs sed -i 's#<\([/]\?\)\(if\|unless\|include\|arg\|property\|macro\|insert_block\)#<\1xacro:\2#g'
xacro.py is deprecated; please use xacro instead
started roslaunch server http://beraru:34417/
SUMMARY
PARAMETERS
 * /abb_robot/gazebo_ros_control/pid_gains/abb_robot_joint_1/d: 1
 * /abb_robot/gazebo_ros_control/pid_gains/abb_robot_joint_1/i: 1
 * /abb_robot/gazebo_ros_control/pid_gains/abb_robot_joint_1/i_clamp: 1
 * /abb_robot/gazebo_ros_control/pid_gains/abb_robot_joint_1/p: 100
 * /abb_robot/gazebo_ros_control/pid_gains/abb_robot_joint_2/d: 1
 * /abb_robot/gazebo_ros_control/pid_gains/abb_robot_joint_2/i: 1
 * /abb_robot/gazebo_ros_control/pid_gains/abb_robot_joint_2/i_clamp: 1
 * /abb_robot/gazebo_ros_control/pid_gains/abb_robot_joint_2/p: 100
 * /abb_robot/gazebo_ros_control/pid_gains/abb_robot_joint_3/d: 1
 * /abb_robot/gazebo_ros_control/pid_gains/abb_robot_joint_3/i: 1
 * /abb_robot/gazebo_ros_control/pid_gains/abb_robot_joint_3/i_clamp: 1
 * /abb_robot/gazebo_ros_control/pid_gains/abb_robot_joint_3/p: 100
 * /abb_robot/gazebo_ros_control/pid_gains/abb_robot_joint_4/d: 1
 * /abb_robot/gazebo_ros_control/pid_gains/abb_robot_joint_4/i: 1
 * /abb_robot/gazebo_ros_control/pid_gains/abb_robot_joint_4/i_clamp: 1
 * /abb_robot/gazebo_ros_control/pid_gains/abb_robot_joint_4/p: 100
 * /abb_robot/gazebo_ros_control/pid_gains/abb_robot_joint_5/d: 1
 * /abb_robot/gazebo_ros_control/pid_gains/abb_robot_joint_5/i: 1
 * /abb_robot/gazebo_ros_control/pid_gains/abb_robot_joint_5/i_clamp: 1
 * /abb_robot/gazebo_ros_control/pid_gains/abb_robot_joint_5/p: 100
 * /abb_robot/gazebo_ros_control/pid_gains/abb_robot_joint_6/d: 1
 * /abb_robot/gazebo_ros_control/pid_gains/abb_robot_joint_6/i: 1
 * /abb_robot/gazebo_ros_control/pid_gains/abb_robot_joint_6/i_clamp: 1
 * /abb_robot/gazebo_ros_control/pid_gains/abb_robot_joint_6/p: 100
 * /gazebo/enable_ros_network: True
 * /robot_description: <?xml version="1....
 * /rosdistro: melodic
 * /rosversion: 1.14.10
 * /use_sim_time: True
NODES
    abb_robot_spawn (gazebo_ros/spawn_model)
    gazebo (gazebo_ros/gzserver)
    gazebo_gui (gazebo_ros/gzclient)
    spawn_urdf (gazebo_ros/spawn_model)
process[abb_robot_spawn-1]: started with pid [22809]
process[spawn_urdf-2]: started with pid [22810]
process[gazebo-3]: started with pid [22811]
process[gazebo_gui-4]: started with pid [22814]
[ INFO] [1607832383.525362033]: Finished loading Gazebo ROS API Plugin.
[ INFO] [1607832383.526581006]: waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting...
[ INFO] [1607832383.643677101]: Finished loading Gazebo ROS API Plugin.
[ INFO] [1607832383.647286837]: waitForService: Service [/gazebo_gui/set_physics_properties] has not been advertised, waiting...
[ INFO] [1607832383.976974650]: waitForService: Service [/gazebo/set_physics_properties] is now available.
[ INFO] [1607832383.997000535, 0.006000000]: Physics dynamic reconfigure ready.
[INFO] [1607832384.072188, 0.000000]: Loading model XML from ros parameter robot_description
[INFO] [1607832384.087355, 0.000000]: Waiting for service /gazebo/spawn_urdf_model
[INFO] [1607832384.089901, 0.000000]: Calling service /gazebo/spawn_urdf_model
Warning [parser.cc:950] XML Element[always_on], child of element[camera] not defined in SDF. Ignoring[always_on]. You may have an incorrect SDF file, or an sdformat version that doesn't support this element.
Warning [parser.cc:950] XML Element[update_rate], child of element[camera] not defined in SDF. Ignoring[update_rate]. You may have an incorrect SDF file, or an sdformat version that doesn't support this element.
[ INFO] [1607832384.390545807, 0.131000000]: Camera Plugin: Using the 'robotNamespace' param: '/'
[ INFO] [1607832384.392933520, 0.131000000]: Camera Plugin (ns = /)  <tf_prefix_>, set to ""
[ INFO] [1607832384.394568860, 0.131000000]: Camera Plugin: Using the 'robotNamespace' param: '/'
[ INFO] [1607832384.396910677, 0.131000000]: Camera Plugin (ns = /)  <tf_prefix_>, set to ""
[ INFO] [1607832384.402130156, 0.131000000]: <robotNamespace> set to: //
[ INFO] [1607832384.402178073, 0.131000000]: <topicName> set to: //camerat265/gyro/sample
[ INFO] [1607832384.402197233, 0.131000000]: <frameName> set to: camerat265_link
[ INFO] [1607832384.402225740, 0.131000000]: <updateRateHZ> set to: 30
[ INFO] [1607832384.402247707, 0.131000000]: <gaussianNoise> set to: 1e-06
[ INFO] [1607832384.402270680, 0.131000000]: <xyzOffset> set to: 0 0 0
[ INFO] [1607832384.402306360, 0.131000000]: <rpyOffset> set to: 0 -0 0
[ INFO] [1607832384.465914537, 0.131000000]: Loading gazebo_ros_control plugin
[ INFO] [1607832384.466008186, 0.131000000]: Starting gazebo_ros_control plugin in namespace: /abb_robot
[ INFO] [1607832384.466488289, 0.131000000]: gazebo_ros_control plugin is waiting for model URDF in parameter [/robot_description] on the ROS param server.
[spawn_urdf-2] process has finished cleanly
log file: /home/beraru/.ros/log/deac11e6-3c94-11eb-aac7-9c305b2b6a57/spawn_urdf-2*.log
[ INFO] [1607832384.587153733, 0.131000000]: Loaded gazebo_ros_control.
[ WARN] [1607832384.649552508, 0.192000000]: Moved backwards in time (probably because ROS clock was reset), re-publishing joint transforms!
[INFO] [1607832384.874098, 0.330000]: Spawn status: SpawnModel: Successfully spawned entity
[abb_robot_spawn-1] process has finished cleanly
log file: /home/beraru/.ros/log/deac11e6-3c94-11eb-aac7-9c305b2b6a57/abb_robot_spawn-1*.log
Mu launch file:
<launch>
      <param command="$(find xacro)/xacro.py $(find abb_robot_model)/urdf/abb_robot.urdf.xacro" name="robot_description"/>
  <rosparam file="$(find abb_robot_model)/config/gazebo_ros_control_params.yaml" command="load"/>
  <node name="abb_robot_spawn" pkg="gazebo_ros" type="spawn_model" output="screen"
          args="-urdf -param robot_description -model abb_robot" />
  <node args="-param robot_description -urdf -model model" name="spawn_urdf" pkg="gazebo_ros" type="spawn_model"/>
     <arg name="gui" value="true"/>
</launch>
Robot files: abb_robot.xacro:
<?xml version="1.0"?>
<robot xmlns:xacro="http://www.ros.org/wiki/xacro">
  <!-- Import all Gazebo-customization elements, including Gazebo colors -->
  <xacro:include filename="$(find abb_robot_model)/urdf/abb_robot.gazebo.xacro" />
  <xacro:include filename="$(find abb_robot_model)/urdf/_d435i.gazebo.xacro" />
  <xacro:include filename="$(find abb_robot_model)/urdf/_d435i.urdf.xacro" />
  <xacro:include filename="$(find abb_robot_model)/urdf/tracker.xacro" />
  <!-- Import Transmissions -->
  <xacro:include filename="$(find abb_robot_model)/urdf/abb_robot.transmission.xacro" />
  <!-- Include Utilities -->
  <xacro:include filename="$(find abb_robot_model)/urdf/utilities.xacro" />
  <!-- some constants -->
  <xacro:property name="safety_controller_k_pos" value="100" />
  <xacro:property name="safety_controller_k_vel" value="2" />
  <xacro:property name="joint_damping" value="0.5" />
  <xacro:property name="max_effort" value="300"/>
  <xacro:property name="max_velocity" value="10"/>
  <xacro:macro name="abb_robot" params="parent hardware_interface robot_name *origin">
  <!--joint between {parent} and mobilePlatform-->
    <joint name="${parent}_${robot_name}_joint" type="fixed">
      <xacro:insert_block name="origin"/>
      <parent link="${parent}"/>
      <child link="${robot_name}_mobilePlatform"/>
    <link name="${robot_name}_mobilePlatform">
    <origin xyz="-2.4 0.92 -2.5" rpy="1.57 0 0"/>
    <mass value="2"/>
    <inertia ixx="0.001"  ixy="0"  ixz="0" iyy="0.001" iyz="0" izz="0.001" />
      <visual>
      <mesh filename="package://abb_robot_model/urdf/meshes/visual/tools/mobilePlatform.stl" scale="0.001 0.001 0.001"/>
    <material name="Grey"/>
    <!--joint between {parent} and link_0-->
    <joint name="${robot_name}_mobilePlatform" type="fixed">
      <parent link="${robot_name}_mobilePlatform"/>
      <child link="${robot_name}_link_0"/>
    <link name="${robot_name}_link_0">
    <mass value="0.050"/>
      <visual>
    <origin xyz="-0.72643375 -0.395 0" rpy="0 0 0"/>
      <mesh filename="package://abb_robot_model/urdf/meshes/visual/link_0.stl" scale="0.001 0.001 0.001"/>
      <collision>
      <mesh filename="package://abb_robot_model/urdf/meshes/collision/link_0_hull.stl" scale="0.001 0.001 0.001"/>
      <self_collision_checking>
      <capsule radius="0.15" length="0.25"/>
      </self_collision_checking>
    <!-- joint between link_0 and link_1 -->
    <joint name="${robot_name}_joint_1" type="revolute">
      <parent link="${robot_name}_link_0"/>
      <child link="${robot_name}_link_1"/>
      <origin xyz="0 0 0.630" rpy="0 0 0"/>
      <axis xyz="0 0 1"/>
      <limit lower="${-180.0 * PI / 180}" upper="${180.0 * PI / 180}"
         effort="${max_effort}" velocity="${max_velocity}" />
      <safety_controller soft_lower_limit="${-179.5 * PI / 180}"
             soft_upper_limit="${179.5 * PI / 180}"
             k_position="${safety_controller_k_pos}"
             k_velocity="${safety_controller_k_vel}"/>
      <dynamics damping="${joint_damping}"/>
    <link name="${robot_name}_link_1">
    <origin xyz="0.0 0.0 0.0" rpy="0 0 0"/>
    <inertia ixx="0.005"  ixy="0"  ixz="0" iyy="0.005" iyz="0" izz="0.005" />
      <visual>
    <origin xyz="-0.331 -0.4645 -0.630" rpy="0 0 0"/>
      <mesh filename="package://abb_robot_model/urdf/meshes/visual/link_1.stl" scale="0.001 0.001 0.001"/>
      <collision>
      <mesh filename="package://abb_robot_model/urdf/meshes/collision/link_1_hull.stl" scale="0.001 0.001 0.001"/>
    <!-- joint between link_1 and link_2 -->
    <joint name="${robot_name}_joint_2" type="revolute">
      <parent link="${robot_name}_link_1"/>
      <child link="${robot_name}_link_2"/>
      <origin xyz="0.60 0.0 0.0" rpy="0 0 0"/>
      <axis xyz="0 1 0"/>
      <limit lower="${-40.0 * PI / 180}" upper="${160.0 * PI / 180}"
      <safety_controller soft_lower_limit="${-39.5 * PI / 180}"
             soft_upper_limit="${159.5 * PI / 180}"
    <link name="${robot_name}_link_2">
    <origin xyz="0.0 0.060 0.0" rpy="0 0 0"/>
      <visual>
    <origin xyz="-.60 -.45 -.630" rpy="0 0 0"/>
      <mesh filename="package://abb_robot_model/urdf/meshes/visual/link_2.stl" scale="0.001 0.001 0.001"/>
      <collision>
      <mesh filename="package://abb_robot_model/urdf/meshes/collision/link_2_hull.stl" scale="0.001 0.001 0.001"/>
    <!-- joint between link_2 and link_3 -->
    <joint name="${robot_name}_joint_3" type="revolute">
      <parent link="${robot_name}_link_2"/>
      <child link="${robot_name}_link_3"/>
      <origin xyz="0 0 1.280" rpy="0 0 0"/>
      <axis xyz="0 1 0"/>
      <limit lower="${-180.0 * PI / 180}" upper="${70.0 * PI / 180}"
             soft_upper_limit="${69.5 * PI / 180}"
    <link name="${robot_name}_link_3">
    <origin xyz="0.030 0.020 0.0" rpy="0 0 0"/>
      <visual>
    <origin xyz="-.6 -.28 ${-.63-1.28}" rpy="0 0 0"/>
      <mesh filename="package://abb_robot_model/urdf/meshes/visual/link_3.stl" scale="0.001 0.001 0.001"/>
      <collision>
      <mesh filename="package://abb_robot_model/urdf/meshes/collision/link_3_hull.stl" scale="0.001 0.001 0.001"/>
    <!-- joint between link_3 and link_4 -->
    <joint name="${robot_name}_joint_4" type="revolute">
      <parent link="${robot_name}_link_3"/>
      <child link="${robot_name}_link_4"/>
      <origin xyz="0.0 0.0 0.20" rpy="0 0 0"/>
      <axis xyz="1 0 0"/>
      <limit lower="${-300.0 * PI / 180}" upper="${300.0 * PI / 180}"
      <safety_controller soft_lower_limit="${-299.5 * PI / 180}"
             soft_upper_limit="${299.5 * PI / 180}"
    <link name="${robot_name}_link_4">
    <origin xyz="0 0.067 0.034" rpy="0 0 0"/>
    <mass value="2.7"/>
    <inertia ixx="0.03"  ixy="0"  ixz="0" iyy="0.01" iyz="0" izz="0.029" />
      <visual>
    <origin xyz="-.6 -0.187 ${-.63-1.28-.2}" rpy="0 0 0"/>
      <mesh filename="package://abb_robot_model/urdf/meshes/visual/link_4.stl" scale="0.001 0.001 0.001"/>
      <collision>
      <mesh filename="package://abb_robot_model/urdf/meshes/collision/link_4_hull.stl" scale="0.001 0.001 0.001"/>
    <!-- joint between link_4 and link_5 -->
    <joint name="${robot_name}_joint_5" type="revolute">
      <parent link="${robot_name}_link_4"/>
      <child link="${robot_name}_link_5"/>
      <origin xyz="1.142 0 0" rpy="0 0 0"/>
      <axis xyz="0 1 0"/>
      <limit lower="${-120.0 * PI / 180}" upper="${120.0 * PI / 180}"
      <safety_controller soft_lower_limit="${-119.5 * PI / 180}"
             soft_upper_limit="${119.5 * PI / 180}"
    <link name="${robot_name}_link_5">
    <origin xyz="0.0 0.0 0.055" rpy="0 0 0"/>
    <mass value="0.025"/>
      <visual>
    <origin xyz="${-.6-1.142} -0.093 ${-.63-1.28-.2}" rpy="0 0 0"/>
      <mesh filename="package://abb_robot_model/urdf/meshes/visual/link_5.stl" scale="0.001 0.001 0.001"/>
      <collision>
      <mesh filename="package://abb_robot_model/urdf/meshes/collision/link_5_hull.stl" scale="0.001 0.001 0.001"/>
    <!-- joint between link_5 and link_6 -->
    <joint name="${robot_name}_joint_6" type="revolute">
      <parent link="${robot_name}_link_5"/>
      <child link="${robot_name}_link_6"/>
      <origin xyz="0.20 0 0" rpy="0 0 0"/>
      <axis xyz="1 0 0"/>
      <limit lower="${-360.0 * PI / 180}" upper="${360.0 * PI / 180}"
      <safety_controller soft_lower_limit="${-359.5 * PI / 180}"
             soft_upper_limit="${359.5 * PI / 180}"
    <link name="${robot_name}_link_6">
    <origin xyz="0.0125 0.0 0.0" rpy="0 0 0"/>
    <mass value="0.010"/>
      <visual>
    <origin xyz="${-.6-1.142-.2} -0.10 ${-.63-1.28-.2}" rpy="0 0 0"/>
      <mesh filename="package://abb_robot_model/urdf/meshes/visual/link_6.stl" scale="0.001 0.001 0.001"/>
      <collision>
      <mesh filename="package://abb_robot_model/urdf/meshes/collision/link_6_hull.stl" scale="0.001 0.001 0.001"/>
    <joint name="${robot_name}_joint_endeffector" type="fixed">
      <parent link="${robot_name}_link_6"/>
      <child link="${robot_name}_link_endEffector"/>
    <link name="${robot_name}_link_endEffector">
    <origin xyz="0.0 0.0 0.0150" rpy="0 0 0"/>
    <inertia ixx="000"  ixy="0"  ixz="0" iyy="0000" iyz="0" izz="000" />
        <visual>
    <origin xyz="0 -0.003 0" rpy="0 0 0"/> <!-- x=front y=right z=up-->
      <mesh filename="package://abb_robot_model/urdf/meshes/visual/tools/gripper.stl" />
    <xacro:include filename="$(find abb_robot_model)/urdf/_d435i.urdf.xacro"/>
     <sensor_d435i parent="${robot_name}_link_4">
        <origin xyz="0.95 -0.003 5" rpy="0 0 0"/>   <!-- x= front y=right z= up-->
      </sensor_d435i>
    <xacro:realsense_T265 sensor_name="camerat265" parent_link="${robot_name}_link_4" rate="30.0">
    <origin rpy="0 0 0" xyz="1 -0.005 5"/>
    <!--origin rpy="0 0 0" xyz="1 -0.005 0.1"/-->
    </xacro:realsense_T265>
    <!--Extensions -->
    <xacro:abb_robot_gazebo robot_name="${robot_name}" />
    <xacro:abb_robot_transmission hardware_interface="${hardware_interface}"/>
  </xacro:macro>
</robot>
abb_robot.urdf.xacro:
<robot name="abb_robot" xmlns:xacro="http://www.ros.org/wiki/xacro">
  <!-- Import Rviz colors -->
  <xacro:include filename="$(find abb_robot_model)/urdf/materials.xacro" />
  <!--Import the abb_robot macro -->
  <xacro:include filename="$(find abb_robot_model)/urdf/abb_robot.xacro"/>
  <!--Parameters -->
  <xacro:arg name="hardware_interface" default="hardware_interface/EffortJointInterface"/>
  <xacro:arg name="robot_name" default="abb_robot"/>
  <xacro:arg name="origin_xyz" default="0 0 0"/>
  <xacro:arg name="origin_rpy" default="0 0 0"/>
  <!-- Fix to world, change if mounted to something -->
  <link name="world"/>
  <!--abb_robot robot-->
  <xacro:abb_robot hardware_interface="$(arg hardware_interface)" robot_name="$(arg robot_name)" parent="world">
    <origin xyz="$(arg origin_xyz)" rpy="$(arg origin_rpy)" />
  </xacro:abb_robot>
</robot>
config file: gazeboroscontrol_params.yaml
 gazebo_ros_control:
  pid_gains:
      abb_robot_joint_1:
        p: 100
        d: 1
        i: 1
        i_clamp: 1
      abb_robot_joint_2:
        p: 100
        d: 1
        i: 1
        i_clamp: 1
      abb_robot_joint_3:
        p: 100
        d: 1
        i: 1
        i_clamp: 1
      abb_robot_joint_4:
        p: 100
        d: 1
        i: 1
        i_clamp: 1
      abb_robot_joint_5:
        p: 100
        d: 1
        i: 1
        i_clamp: 1
      abb_robot_joint_6:
        p: 100
        d: 1
        i: 1
        i_clamp: 1
joint_limits:
  abb_robot_joint_1:
    has_velocity_limits: true
    max_velocity: 10
    has_acceleration_limits: false
    max_acceleration: 0
  abb_robot_joint_2:
    max_velocity: 10
    max_acceleration: 0
  abb_robot_joint_3:
    max_velocity: 10
    max_acceleration: 0
  abb_robot_joint_4:
    max_velocity: 10
    max_acceleration: 0
  abb_robot_joint_5:
    max_velocity: 10
    max_acceleration: 0
  abb_robot_joint_6:
    max_velocity: 10
    max_acceleration: 0
other files for transmission and camera plugins.
Asked by beraru on 2020-12-12 23:34:36 UTC
It might help running it with extra_gazebo_args:="--verbose" to see if Gazebo shows some errors.
Asked by Carlos Agüero on 2020-12-18 14:00:29 UTC
hi ,Carlos kindly check the answers it contains verbose enabled
Asked by beraru on 2020-12-20 10:57:17 UTC
... logging to /home/beraru/.ros/log/dd741336-42da-11eb-8077-9c305b2b6a57/roslaunch-beraru-17138.log Checking log directory for disk usage. This may take a while. Press Ctrl-C to interrupt Done checking log file disk usage. Usage is <1GB.
started roslaunch server http://beraru:35545/
SUMMARY
PARAMETERS * /gazebo/enable_ros_network: True * /rosdistro: melodic * /rosversion: 1.14.10 * /use_sim_time: True
NODES / gazebo (gazebo_ros/gzserver) gazebo_gui (gazebo_ros/gzclient)
process[gazebo-1]: started with pid [17153] process[gazebo_gui-2]: started with pid [17156] Gazebo multi-robot simulator, version 9.0.0 Copyright (C) 2012 Open Source Robotics Foundation. Released under the Apache 2 License. http://gazebosim.org
[Wrn] [GuiIface.cc:199] g/gui-plugin is really loading a SystemPlugin. To load a GUI plugin please use --gui-client-plugin Gazebo multi-robot simulator, version 9.0.0 Copyright (C) 2012 Open Source Robotics Foundation. Released under the Apache 2 License. http://gazebosim.org
[ INFO] [1608479775.113974205]: Finished loading Gazebo ROS API Plugin. [ INFO] [1608479775.115090590]: waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting... [Msg] Waiting for master. [Msg] Connected to gazebo master @ http://127.0.0.1:11345 [Msg] Publicized address: 192.168.0.123 [ INFO] [1608479775.153962743]: Finished loading Gazebo ROS API Plugin. [ INFO] [1608479775.155156280]: waitForService: Service [/gazebo_gui/set_physics_properties] has not been advertised, waiting... [Msg] Waiting for master. [Msg] Connected to gazebo master @ http://127.0.0.1:11345 [Msg] Publicized address: 192.168.0.123 [ INFO] [1608479775.402456716, 0.005000000]: waitForService: Service [/gazebo/set_physics_properties] is now available. [ INFO] [1608479775.418985375, 0.021000000]: Physics dynamic reconfigure ready. Warning [parser.cc:950] XML Element[always_on], child of element[camera] not defined in SDF. Ignoring[always_on]. You may have an incorrect SDF file, or an sdformat version that doesn't support this element. Warning [parser.cc:950] XML Element[update_rate], child of element[camera] not defined in SDF. Ignoring[update_rate]. You may have an incorrect SDF file, or an sdformat version that doesn't support this element. Warning [parser.cc:950] XML Element[always_on], child of element[camera] not defined in SDF. Ignoring[always_on]. You may have an incorrect SDF file, or an sdformat version that doesn't support this element. Warning [parser.cc:950] XML Element[update_rate], child of element[camera] not defined in SDF. Ignoring[update_rate]. You may have an incorrect SDF file, or an sdformat version that doesn't support this element. [Wrn] [Event.cc:61] Warning: Deleting a connection right after creation. Make sure to save the ConnectionPtr from a Connect call [ INFO] [1608479776.032435365, 0.357000000]: Camera Plugin: Using the 'robotNamespace' param: '/' [ INFO] [1608479776.034633511, 0.357000000]: Camera Plugin (ns = /) , set to "" [ INFO] [1608479776.036191177, 0.357000000]: Camera Plugin: Using the 'robotNamespace' param: '/' [Wrn] [msgs.cc:1852] Conversion of sensor type[wideanglecamera] not supported. [Wrn] [msgs.cc:1852] Conversion of sensor type[wideanglecamera] not supported. [ INFO] [1608479776.038855743, 0.357000000]: Camera Plugin (ns = /) , set to "" [ INFO] [1608479776.042810792, 0.357000000]: set to: // [ INFO] [1608479776.042852906, 0.357000000]: set to: //camerat265/gyro/sample [ INFO] [1608479776.042881275, 0.357000000]: set to: camerat265_link [ INFO] [1608479776.042914226, 0.357000000]: set to: 30 [ INFO] [1608479776.042939428, 0.357000000]: set to: 1e-06 [ INFO] [1608479776.042969988, 0.357000000]: set to: 0 0 0 [ INFO] [1608479776.043017601, 0.357000000]: set to: 0 -0 0 [Wrn] [msgs.cc:1852] Conversion of sensor type[wideanglecamera] not supported. [Wrn] [msgs.cc:1852] Conversion of sensor type[wideanglecamera] not supported. [Wrn] [msgs.cc:1852] Conversion of sensor type[wideanglecamera] not supported. [Wrn] [msgs.cc:1852] Conversion of sensor type[wideanglecamera] not supported. [Wrn] [msgs.cc:1852] Conversion of sensor type[wideanglecamera] not supported. [Wrn] [msgs.cc:1852] Conversion of sensor type[wideanglecamera] not supported. [Err] [ModelDatabase.cc:390] Unable to parse model.config for model[http://gazebosim.org/models/bin_4_dropping_task]
[Wrn] [Publisher.cc:141] Queue limit reached for topic /gazebo/default/pose/local/info, deleting message. This warning is printed only once.
Asked by beraru on 2020-12-20 10:58:06 UTC
