Why does my differential drive robot wheels move as if flushed in a toilet?
Hi. I'm new to ROS and Gazebo simulation. I tried to create a differential drive robot for various experiments such sa SLAM etc.
My problem right now is that my driven wheels drift as if they're not attached to the main link and whenever I run teleop, they rotate and move as if they were flushed in a toilet and the wheels suddenly stick together and continue to rotate.
Here is a link to a video I took showing my problem. https://www.youtube.com/watch?v=0gAoxdEr034
Here is a link where I uploaded my files as pasting them here would make this post really long. I would really appreciate it if you would have a look. https://github.com/jcjmagno/test_robot
Here is a snippet of the urdf code:
<link name="base_link">
<joint name="base_joint" type="fixed">
<parent link="base_link"/>
<child link="chassis"/>
<link name="chassis">
<origin xyz="0.0 0.0 0.0" rpy="0.0 0.0 0.0"/>
<mass value="25"/>
<inertia ixx="3.002" ixy="0.0" ixz="0.0" iyy="4.011" iyz="0.0" izz="2.8465"/>
<visual name="chassis_visual">
<box size="0.962 0.664 1" />
<collision name="chassis_collision">
<link name="front_left_wheel">
<origin xyz="0.3 0.232 -0.525" rpy="0.0 1.5707 1.5707"/>
<mass value="5"/>
<inertia ixx="0.02" ixy="0.0" ixz="0.0" iyy="0.02" iyz="0.0" izz="0.02"/>
<visual name="front_left_wheel_visual">
<cylinder radius="0.1" length="0.1"/>
<collision name="front_left_wheel_collision">
<link name="front_right_wheel">
<origin xyz="0.3 -0.232 -0.525" rpy="0.0 1.5707 1.5707"/>
<mass value="5"/>
<visual name="front_right_wheel_visual">
<collision name="front_right_wheel_collision">
<link name="rear_left_wheel">
<origin xyz="-0.3 0.232 -0.525" rpy="0.0 1.5707 1.5707"/>
<mass value="5"/>
<visual name="rear_left_wheel_visual">
<collision name="rear_left_wheel_collision">
<link name="rear_right_wheel">
<origin xyz="-0.3 -0.232 -0.525" rpy="0.0 1.5707 1.5707"/>
<mass value="5"/>
<visual name="rear_right_wheel_visual">
<collision name="rear_right_wheel_collision">
<joint name="front_left_wheel_hinge" type="continuous">
<parent link="chassis"/>
<child link="front_left_wheel"/>
<axis xyz="0.0 0.0 1.0"/>
<limit effort="100" velocity="100"/>
<joint name="front_right_wheel_hinge" type="continuous">
<child link="front_right_wheel"/>
<joint name="rear_left_wheel_hinge" type="fixed">
<child link="rear_left_wheel"/>
<dynamics friction="0.0" />
<limit lower="0.0" upper="0.0" effort="100" velocity="100"/>
<joint name="rear_right_wheel_hinge" type="fixed">
<child link="rear_right_wheel"/>
<gazebo>
<robotNamespace>/test_robot</robotNamespace> -->
<transmission name="chassis_to_front_left_wheel_transmission">
<actuator name="motor1">
</actuator>
<joint name="front_left_wheel_hinge">
</transmission>
<transmission name="chassis_to_front_right_wheel_transmission">
<actuator name="motor2">
</actuator>
<joint name="front_right_wheel_hinge">
</transmission>
<gazebo>
<plugin name="differential_drive_controller" filename="libgazebo_ros_diff_drive.so">
<updateRate>20</updateRate>
<leftJoint>front_left_wheel_hinge</leftJoint>
<rightJoint>front_right_wheel_hinge</rightJoint>
<wheelSeparation>0.464</wheelSeparation>
<wheelDiameter>0.2</wheelDiameter>
<wheelAcceleration>1.0</wheelAcceleration>
<wheelTorque>20</wheelTorque>
<commandTopic>/test_robot/diff_drive_controller/cmd_vel</commandTopic>
<odometryTopic>/test_robot/diff_drive_controller/odom</odometryTopic>
<odometryFrame>/test_robot/diff_drive_controller/odom</odometryFrame>
<odometrySource>1</odometrySource>
<publishWheelTF>true</publishWheelTF>
<publishOdom>true</publishOdom>
<publishWheelJointState>true</publishWheelJointState>
<legacyMode>false</legacyMode>
Here is a snippet of the diff_drive.yaml code:
testrobot: jointstatecontroller: type: jointstatecontroller/JointStateController publishrate: 50
diffdrivecontroller: type : "diffdrivecontroller/DiffDriveController" leftwheel : 'frontleftwheelhinge' rightwheel : 'frontrightwheelhinge' publishrate: 50.0 # default: 50 posecovariancediagonal : [0.0, 0.0, 0.0, 0.0, 0.0, 0.0] twistcovariance_diagonal: [0.0, 0.0, 0.0, 0.0, 0.0, 0.0]
# Wheel separation and diameter. These are both optional.
# diff_drive_controller will attempt to read either one or both from the
# URDF if not specified as a parameter
wheel_separation : 0.464
wheel_radius : 0.1
# Wheel separation and radius multipliers
wheel_separation_multiplier: 1.0 # default: 1.0
wheel_radius_multiplier : 1.0 # default: 1.0
# Velocity commands timeout [s], default 0.5
cmd_vel_timeout: 0.25
# Base frame_id
base_frame_id: chassis #default: base_link
# Velocity and acceleration limits
# Whenever a min_* is unspecified, default to -max_*
linear:
x:
has_velocity_limits : true
max_velocity : 1.0 # m/s
min_velocity : -0.5 # m/s
has_acceleration_limits: true
max_acceleration : 0.8 # m/s^2
min_acceleration : -0.4 # m/s^2
has_jerk_limits : true
max_jerk : 5.0 # m/s^3
angular:
z:
max_velocity : 1.7 # rad/s
max_acceleration : 1.5 # rad/s^2
max_jerk : 2.5 # rad/s^3
Tried on: Ubuntu 18.04 LTS, ROS Melodic, Gazebo 9 Ubuntu 20.04 LTS, ROS Noetic, Gazebo 11
Asked by jcjmagno on 2020-12-14 02:14:53 UTC
While I don't have a straightforward answer to urdf, but we have diff_drive demo available in sdf used in Ignition. I believe Gazebo supports both urdf and sdf, so if you need a reference to compare against, it might be helpful to take a look here https://github.com/ignitionrobotics/ign-gazebo/blob/ign-gazebo4/examples/worlds/diff_drive.sdf and this is the demo plugin used in Ignition https://github.com/ignitionrobotics/ign-gazebo/tree/ign-gazebo4/src/systems/diff_drive
Hope this helps
Asked by claireyywang on 2020-12-18 14:12:21 UTC
