Actor's animation stops working when trajectory is added
I am following the official tutorial Make an animated model (actor). I can successfully load a model and override its animation with the <animation>
tag, like in the following code:
<?xml version="1.0" ?>
<sdf version="1.6">
<world name="default">
<uri>model://sun</uri>
<actor name="actor">
<skin>
<filename>sitting.dae</filename>
</skin>
<animation name="animation">
<filename>walk.dae</filename>
</animation>
</actor>
</world>
However after adding a trajectory, all animations stop and the model ends doing a T pose (standing with open arms) without any animation. If I remove the <animation>
tag, the animation is loaded properly and the model follows the trajectory. The provided sample code has the same behavior:
<sdf version="1.6">
<skin>
</skin>
</animation>
<script>
<trajectory id="0" type="walking">
<waypoint>
<time>0</time>
<pose>0 2 0 0 0 -1.57</pose>
</waypoint>
<waypoint>
<time>2</time>
<pose>0 -2 0 0 0 -1.57</pose>
</waypoint>
<waypoint>
<time>2.5</time>
<pose>0 -2 0 0 0 1.57</pose>
</waypoint>
<waypoint>
<time>7</time>
<pose>0 2 0 0 0 1.57</pose>
</waypoint>
<waypoint>
<time>7.5</time>
</waypoint>
</trajectory>
</script>
</actor>
</world>
I am using Ubuntu 16.04 and I tried Gazebo versions 8, 9 (both from PPA) and 10 (compiling from source). The error happen to all three versions. Any ideas?
Asked by Silas Alves on 2020-12-14 16:29:34 UTC
