multicamera: compressed images only work with the 1st camera
I'm getting an error when using the multicamera. It looks like compressed images only work with the 1st camera.
Bug? Any workarounds?
Thanks.
Command:
gzserver -s libgazebo_ros_init.so -s libgazebo_ros_factory.so install/orca_vision/share/orca_vision/worlds/test.world
Results:
[INFO] camera_controller: Publishing left camera info to [/stereo/left/camera_info]
[ERROR] camera_controller: Failed to load plugin image_transport/compressed_pub, error string: parameter 'format' has already been declared
[INFO] camera_controller: Publishing right camera info to [/stereo/right/camera_info]
ROS topics:
/clock
/parameter_events
/rosout
/stereo/left/image_raw
/stereo/left/image_raw/compressed
/stereo/left/image_raw/compressedDepth
/stereo/left/image_raw/theora
/stereo/right/image_raw
/stereo/right/image_raw/compressedDepth
/stereo/right/image_raw/theora
test.world:
<?xml version="1.0"?>
<sdf version="1.6">
<world name="default">
<!-- Sun -->
<uri>model://sun</uri>
<!-- Stereo camera model -->
<model name="camera_model">
<pose>0 0 -2 0 1.570796327 0</pose>
<!-- Not static: the motion plugin moves the camera around -->
<static>false</static>
<link name="camera_link">
<!-- Turn gravity off, otherwise the camera moves toward the floor -->
<gravity>0</gravity>
<inertial> <!-- inertial tag is REQUIRED for Gazebo -->
<pose frame=''>0 0 0 0 0 0</pose>
<mass>1</mass>
<ixx>0.1</ixx>
<iyy>0.1</iyy>
<izz>0.1</izz>
<visual name='camera_link_visual'>
<size>0.02 0.4 0.05</size>
<sensor type="multicamera" name="stereo">
<pose>0 0 0 0 0 0</pose>
<camera name="left">
<!-- Left camera frame == camera_link -->
<horizontal_fov>1.4</horizontal_fov>
<width>800</width>
<height>600</height>
<format>R8G8B8</format>
<near>0.02</near>
<far>300</far>
<noise>
<type>gaussian</type>
<!-- Noise is sampled independently per pixel on each frame.
That pixel's noise value is added to each of its color
channels, which at that point lie in the range [0,1]. -->
<mean>0.0</mean>
<stddev>0.007</stddev>
</noise>
<camera name="right">
<!-- Right camera frame is 0.4m to the right (-0.4m to the left) of camera_link -->
<pose>0 -0.4 0 0 0 0</pose>
<width>800</width>
<near>0.02</near>
<far>300</far>
<noise>
<mean>0.0</mean>
</noise>
<plugin name="camera_controller" filename="libgazebo_ros_camera.so">
<!-- Omit camera_name, will default to sensor name -->
<!-- Omit frame_name, will default to link name -->
<!-- The baseline value is the distance between the 2 cameras. It shows up in the
camera info projection matrix. In theory it can be gleaned by looking at the
pose tags of the 2 cameras above, but in practice we need to set it using the
hack_baseline tag. -->
<hack_baseline>0.4</hack_baseline>
</world>
Asked by clydemcqueen on 2020-12-16 15:48:53 UTC
