Error openning model with .dae meshes : what(): bad lexical cast: source type value could not be interpreted as target
I am trying to add a model I created using a .dae file as meshe in gazebo, but I am getting the following error:
terminate called after throwing an instance of 'boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<boost::bad_lexical_cast> >'
The model.sdf is:
<?xml version="1.0" ?>
<sdf version="1.5">
<model name="Supermarket">
<mesh>
<uri>model://Supermarket/meshes/gicshelf.dae</uri>
</mesh>
<mesh>
</mesh>
I was using a different .dae before and it was working just fine, so I guess the problem is in the new .dae file, but I have no idea what to change to make it work. I am able to open this same .dae file in a online .dae viewer.
Asked by rezenders on 2020-12-17 07:05:38 UTC
Is the mesh using a texture? If so, double-check that the path to the texture in the .dae can be found by Gazebo.
Asked by Carlos Agüero on 2020-12-18 14:10:27 UTC
maybe a locale issue?
Asked by iche033 on 2020-12-18 14:20:22 UTC
