Differential drive robot wheels not attached to body, spawn at 0 0 0
I have created a differential drive robot to learn line following with a camera attached to it. My URDF was working correctly when changeing the innertiavalues of my body parts the wheels seem to spawn at 0 0 0 under the robot. The robot will not move, was moving when the wheels were attached but innertia was wrong. I can't seem to figure out what I am doing wrong . I have tried to change different values to no end. Image from Gazebo
The robot model is correct in Rviz
Here is my Urdf, I know this is not the most efficient way to do it, but I am hoping i don't need to rewrite using xacro to fix this `<?xml version="1.0"?>
<material name="red">
<color rgba="0.8 0 0 1"/>
<material name="blue">
<color rgba="0 0 0.8 1"/>
<material name="black">
<color rgba="0 0 0 1"/>
<material name="white">
<color rgba="1 1 1 1"/>
<link name="base_link">
<visual>
<cylinder length="0.023" radius="0.0825"/>
<material name="red"/>
<collision>
<mass value="0.1"/>
<inertia ixx="0.0007" ixy="0.0" ixz="0.0" iyy="0.0007" iyz="0.0" izz="0.0007"/>
<link name="base_footprint">
<joint name="footprint_to_base" type="fixed">
<parent link="base_footprint"/>
<child link="base_link"/>
<origin xyz="0 0 0.06"/>
<link name="odom">
<joint name="footprint_to_odom" type="fixed">
<child link="odom"/>
<origin xyz="0 0 0"/>
<link name="left_wheel">
<visual>
<origin rpy="1.57075 0 0" xyz="0 0 0"/>
<cylinder length="0.008" radius="0.035"/>
<material name="black"/>
<collision>
<avix xyz="0 -1 0" />
<origin rpy="1.57075 0 0" xyz="-1 0 0"/>
<mass value="0.015"/>
<inertia ixx="0.00002" ixy="0.0" ixz="0.0" iyy="0.00002" iyz="0.0" izz="0.00002"/>
<joint name="base_to_left_wheel" type="continuous">
<axis xyz="0 1 0" />
<parent link="base_link"/>
<child link="left_wheel"/>
<origin xyz="0 0.0825 0"/>
<transmission name="left_wheel_trans">
<joint name="base_to_left_wheel">
<actuator name="left_wheel_motor">
</actuator>
</transmission>
<gazebo reference="left_wheel">
<mu1 value="100000.0"/>
<mu2 value="3000000.0"/>
<kp value="10000000.0" />
<kd value="100000.0" />
<material>Gazebo/Grey</material>
<link name="right_wheel">
<visual>
<collision>
<joint name="base_to_right_wheel" type="continuous">
<child link="right_wheel"/>
<origin xyz="0 -0.0825 0"/>
<transmission name="right_wheel_trans">
<joint name="base_to_right_wheel">
<actuator name="right_wheel_motor">
</actuator>
</transmission>
<gazebo reference="right_wheel">
<link name="head">
<visual>
<box size="0.03 0.03 0.03"/>
<material name="blue"/>
<collision>
<mass value="0.02"/>
<inertia ixx="0.000005" ixy="0.0" ixz="0.0" iyy="0.000005" iyz="0.0" izz="0.000005"/>
<joint name="base_to_head" type="fixed">
<child link="head"/>
<origin xyz="0.07 0 0.015"/>
<link name="passive_wheel_holder">
<visual>
<cylinder length="0.02" radius="0.015"/>
<material name="white"/>
<collision>
<joint name="base_to_passive_wheel_holder" type="fixed">
<child link="passive_wheel_holder"/>
<origin xyz="0.07 0 -0.01"/>
<link name="passive_wheel">
<visual>
<sphere radius="0.015"/>
<collision>
<gazebo reference="passive_wheel">
<mu1 value="0.0"/>
<mu2 value="0.0"/>
<kp value="1000.0" />
<kd value="1000.0" />
<slip1>1.0</slip1>
<slip2>1.0</slip2>
<joint name="passive_wheel_holder_to_passive_wheel" type="fixed">
<parent link="passive_wheel_holder"/>
<child link="passive_wheel"/>
<origin xyz="0 0 -0.01"/>
<link name = "camera">
<visual>
<box size="0.02 0.02 0.02"/>
<collision>
<mass value="0.01"/>
<inertia ixx="0.000001" ixy="0.0" ixz="0.0" iyy="0.000001" iyz="0.0" izz="0.000001"/>
<joint name="camera_to_head" type="fixed">
<origin xyz = "0 0 0.025"/>
<parent link = "head"/>
<child link = "camera"/>
<gazebo>
<legacyModeNS>true</legacyModeNS>
<plugin name="joint_state_publisher" filename="libgazebo_ros_joint_state_publisher.so">
<jointName>base_to_left_wheel, base_to_right_wheel</jointName>
<plugin name="p3d_base_controller" filename="libgazebo_ros_p3d.so">
<alwaysOn>true</alwaysOn>
<updateRate>50.0</updateRate>
<bodyName>base_link</bodyName>
<topicName>ground_truth</topicName>
<gaussianNoise>0.01</gaussianNoise>
<frameName>map</frameName>
<xyzOffsets>0 0 0</xyzOffsets>
<rpyOffsets>0 0 0</rpyOffsets>
<!-- camera -->
enter code here
<gazebo>
<robotNamespace>/differential_robot_cam</robotNamespace>
And This is my launch file to run everything except the line following algorithm
<include file="$(find differential_robot_line_186105iacb)/launch/gazebo.launch">
<arg name="model" value="$(arg model)" />
<node name="transform" pkg="transform_frame" type="move">
<remap from="/cmd_vel" to="diff_drive_controller/cmd_vel"/>
</node>
<rosparam command="load"
file="$(find differential_robot_line_186105iacb)/config/joints.yaml"
ns="joint_state_controller" />
file="$(find differential_robot_line_186105iacb)/config/diffdrive.yaml"
ns="diff_drive_controller" />
<node name="controller_spawner" pkg="controller_manager" type="spawner"
args="
--shutdown-timeout 3"/>
<node name="teleop_twist_keyboard" pkg="teleop_twist_keyboard" type="teleop_twist_keyboard.py">
</node>
<node name="rqt_robot_steering" pkg="rqt_robot_steering" type="rqt_robot_steering">
<param name="default_topic" value="diff_drive_controller/cmd_vel"/>
</node>
Asked by MASTERLLAMACHEESE on 2020-12-22 10:28:25 UTC
Update: Seems to be an issue with intertia, as the inertia for the wheel can't be set below 0.5kg*m^2, but i need my wheel mass to be 0.015kg, setting the inertia values to what they are supposed to be using calculations from here . Makes wheels spawn at 0 0 0 and the robot to not function properly also error [param.cc:451] stated to appear when trying to fix. Still looking for solution and or suggestions from here.
Asked by MASTERLLAMACHEESE on 2021-01-05 07:17:08 UTC
