[ERROR] [launch]: process[gazebo-1] process has died [pid 75378, exit code 255, cmd 'gazebo --verbose -s libgazebo_ros_factory.so'].
Hello, I am new to the gazebo, after installing ROS2 and gym-gazebo2 while I try to run an example I get the following error, can someone help me with it?
duttonide@ubuntu:~/ros2learn/experiments/examples/MARA$ ros2 launch mara_gazebo mara.launch.py --urdf mara_robot_gripper_140
[INFO] [launch]: process[gazebo-1]: started with pid [75378]
[INFO] [launch]: process[robot_state_publisher-2]: started with pid [75379]
[INFO] [launch]: process[spawn_mara.py-3]: started with pid [75380]
[INFO] [launch]: process[hros_cognition_mara_components-4]: started with pid [75381]
Initialize urdf model from file: /home/duttonide/ros2_mara_ws/install/share/mara_description/urdf/mara_robot_gripper_140.urdf
Parsing robot urdf xml string.
Link table had 1 children
Link base_link had 1 children
Link base_robot had 1 children
Link motor1_link had 2 children
Link motor1_cover had 0 children
Link motor2_link had 1 children
Link motor3_link had 2 children
Link motor3_cover had 0 children
Link motor4_link had 1 children
Link motor5_link had 2 children
Link motor5_cover had 0 children
Link motor6_link had 3 children
Link ee_link had 0 children
Link tool0 had 0 children
Link gripper_adapter had 1 children
Link robotiq_adapter_link had 1 children
Link robotiq_arg2f_base_link had 4 children
Link right_outer_knuckle had 1 children
Link right_outer_finger had 1 children
Link right_inner_finger had 0 children
Link left_inner_knuckle had 0 children
Link left_outer_knuckle had 1 children
Link left_outer_finger had 1 children
Link left_inner_finger had 0 children
Link right_inner_knuckle had 0 children
got segment base_link
got segment base_robot
got segment ee_link
got segment gripper_adapter
got segment left_inner_finger
got segment left_inner_knuckle
got segment left_outer_finger
got segment left_outer_knuckle
got segment motor1_cover
got segment motor1_link
got segment motor2_link
got segment motor3_cover
got segment motor3_link
got segment motor4_link
got segment motor5_cover
got segment motor5_link
got segment motor6_link
got segment right_inner_finger
got segment right_inner_knuckle
got segment right_outer_finger
got segment right_outer_knuckle
got segment robotiq_adapter_link
got segment robotiq_arg2f_base_link
got segment table
got segment tool0
got segment world
Couldn't set scheduling priority and policy: Operation not permitted
node_name hros_cognition_ubuntu
Adding fixed segment from world to table
Adding fixed segment from table to base_link
Adding fixed segment from base_link to base_robot
Adding moving segment from base_robot to motor1_link
Adding fixed segment from motor1_link to motor1_cover
Adding moving segment from motor1_link to motor2_link
Adding moving segment from motor2_link to motor3_link
Adding fixed segment from motor3_link to motor3_cover
Adding moving segment from motor3_link to motor4_link
Adding moving segment from motor4_link to motor5_link
Adding fixed segment from motor5_link to motor5_cover
Adding moving segment from motor5_link to motor6_link
Adding fixed segment from motor6_link to ee_link
Adding fixed segment from motor6_link to tool0
Adding fixed segment from motor6_link to gripper_adapter
Adding fixed segment from gripper_adapter to robotiq_adapter_link
Adding fixed segment from robotiq_adapter_link to robotiq_arg2f_base_link
Adding moving segment from robotiq_arg2f_base_link to right_outer_knuckle
Adding fixed segment from right_outer_knuckle to right_outer_finger
Adding moving segment from right_outer_finger to right_inner_finger
Adding moving segment from robotiq_arg2f_base_link to left_inner_knuckle
Adding moving segment from robotiq_arg2f_base_link to left_outer_knuckle
Adding fixed segment from left_outer_knuckle to left_outer_finger
Adding moving segment from left_outer_finger to left_inner_finger
Adding moving segment from robotiq_arg2f_base_link to right_inner_knuckle
[INFO] [hros_cognition_ubuntu]: HROSCognitionMaraComponentsNode::on_configure() is called.
====================== Reading link order ======================
topic name: /hrim_actuator_rotaryservo_000000000001/trajectory_axis2
topic name: /hrim_actuator_rotaryservo_000000000001/trajectory_axis1
topic name: /hrim_actuator_rotaryservo_000000000002/trajectory_axis1
topic name: /hrim_actuator_rotaryservo_000000000002/trajectory_axis2
topic name: /hrim_actuator_rotaryservo_000000000003/trajectory_axis1
topic name: /hrim_actuator_rotaryservo_000000000003/trajectory_axis2
====================== Name of the motors ======================
motor_names: motor1
motor_names: motor2
motor_names: motor3
motor_names: motor4
motor_names: motor5
motor_names: motor6
====================== Subscribers and Publishers ======================
Subscribe at /hrim_actuator_rotaryservo_000000000001/state_axis2
New publisher at /hrim_actuator_rotaryservo_000000000001/goal_axis2
Subscribe at /hrim_actuator_rotaryservo_000000000001/state_axis1
New publisher at /hrim_actuator_rotaryservo_000000000001/goal_axis1
Subscribe at /hrim_actuator_rotaryservo_000000000002/state_axis1
New publisher at /hrim_actuator_rotaryservo_000000000002/goal_axis1
Subscribe at /hrim_actuator_rotaryservo_000000000002/state_axis2
New publisher at /hrim_actuator_rotaryservo_000000000002/goal_axis2
Subscribe at /hrim_actuator_rotaryservo_000000000003/state_axis1
New publisher at /hrim_actuator_rotaryservo_000000000003/goal_axis1
Subscribe at /hrim_actuator_rotaryservo_000000000003/state_axis2
New publisher at /hrim_actuator_rotaryservo_000000000003/goal_axis2
[INFO] [hros_cognition_ubuntu]: HROSCognitionMaraComponentsNode::on_configure() is finished.
Gazebo multi-robot simulator, version 9.0.0
http://gazebosim.org
[INFO] [minimal_client]: service not available, waiting again...
[Msg] Waiting for master.
[Msg] Publicized address: 192.168.70.145
[INFO] [gazebo_ros_node]: ROS was initialized without arguments.
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/ament_index"
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/colcon-core"
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/doc"
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/gripper_minimal_service"
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/gripper_minimal_subscriber"
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/hans_modular_gazebo"
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/hans_t30_description"
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/hans_t49_description"
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/hans_t9_4_description"
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/hrim_actuator_gripper_msgs"
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/hrim_actuator_gripper_srvs"
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/hrim_actuator_rotaryservo_actions"
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/hrim_actuator_rotaryservo_msgs"
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/hrim_actuator_rotaryservo_srvs"
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/hrim_generic_msgs"
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/hrim_generic_srvs"
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/hros_cognition_mara_components"
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/mara_bringup"
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/mara_contact_publisher"
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/mara_description"
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/mara_gazebo"
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/mara_gazebo_plugins"
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/mara_minimal_publisher"
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/mara_minimal_subscriber"
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/mara_minimal_trajectory_action"
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/mara_utils_scripts"
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/orocos_kdl"
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/python_orocos_kdl"
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/robotiq_140_gripper_description"
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/robotiq_85_gripper_description"
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/robotiq_gazebo"
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/robotiq_gripper_gazebo_plugins"
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/robotiq_hande_gripper_description"
[Err] [InsertModelWidget.cc:405] Missing model.config for model "/home/duttonide/ros2_mara_ws/install/share/urdfdom_py"
[INFO] [minimal_client]: Result True SpawnEntity: Successfully spawned entity [mara]
[INFO] [launch]: process[spawn_mara.py-3]: process has finished cleanly
[Err] [REST.cc:205] Error in REST request
libcurl: (51) SSL: no alternative certificate subject name matches target host name 'api.ignitionfuel.org'
[Wrn] [Visual.cc:1019] Unable to get Material[Gazebo/Brown] for Geometry[mara::table::table_visual. Object will appear white
[Wrn] [Visual.cc:1019] Unable to get Material[Gazebo/Brown] for Geometry[mara::table::table_visual_1. Object will appear white
[Wrn] [Visual.cc:1019] Unable to get Material[Gazebo/Brown] for Geometry[mara::table::table_visual_2. Object will appear white
[Wrn] [Visual.cc:1019] Unable to get Material[Gazebo/Brown] for Geometry[mara::table::table_visual_3. Object will appear white
[Wrn] [Visual.cc:1019] Unable to get Material[Gazebo/Brown] for Geometry[mara::table::table_visual_4. Object will appear white
gzclient: /build/ogre-1.9-B6QkmW/ogre-1.9-1.9.0+dfsg1/OgreMain/src/OgreNode.cpp:630: virtual void Ogre::Node::setScale(const Ogre::Vector3&): Assertion `!inScale.isNaN() && "Invalid vector supplied as parameter"' failed.
[INFO] [joint_state]: Going to publish joint [motor1]
[INFO] [joint_state]: Going to publish joint [motor2]
[INFO] [joint_state]: Going to publish joint [motor3]
[INFO] [joint_state]: Going to publish joint [motor4]
[INFO] [joint_state]: Going to publish joint [motor5]
[INFO] [joint_state]: Going to publish joint [motor6]
[INFO] [joint_state]: Going to publish joint [joint_finger]
[ERROR] [rclcpp]: Couldn't add guard_condition to wait set: guard_conditions set is full, at /tmp/binarydeb/ros-crystal-rcl-0.6.6/src/rcl/wait.c:411
terminate called after throwing an instance of 'std::runtime_error'
what(): Couldn't fill wait set
Asked by duttonide on 2020-12-22 11:49:54 UTC
