Gazebo Plugin Debugging with VSCode
Hello Friends, Due to scarcity of Gazebo Plugin tutorials, I would like to learn it using debugging process. For that purpose, I created a simple Gazebo Model Plugin named model_push.cc. [The code is in the very bottom part.] And I also added the plugin inside .sdf file
<plugin name="model_push" filename="libmodel_push.so"/>
When I try to spawn a model ( without debugging purpose), then I see the correct output as in the following picture. image description
However, If I try to debug the plugin using VSCode, something strange happens;
in the Debuggin console of VSCode, image description
The program is stopped right now in the line 36, I am writing the code "this->model->GetName() " to see the name inside debugging console. I am getting an error because the method was not found.
image description
Do you have any idea how to fix it ? Thank you
#include <functional>
#include <gazebo/gazebo.hh>
#include <ignition/math/Vector3.hh>
namespace gazebo
  class ModelPush : public ModelPlugin
  this->model = _parent;
      std::cout << "Model is loaded" << std::endl;
      // simulation iteration.
          std::bind(&ModelPush::OnUpdate, this));
    // Pointer to the model
    public: void OnUpdate()
      std::cout << this->model->GetName() << std::endl;
  GZ_REGISTER_MODEL_PLUGIN(ModelPush)
Asked by erdisayar on 2020-12-31 11:27:11 UTC
