Can Ignition Gazebo simulate a hydraulic-actuated robot?
I would like to simulate a hydraulic biped humanoid robot using Ignition Gazebo.
If Ignition Gazebo is unable to simulate this, can you suggest a simulator that can?
Asked by samq on 2021-01-04 16:52:57 UTC
I don't see a reason why you wouldn't be able to simulate it. Each actuator will probably be modeled as a prismatic joint, and you may need to write a plugin to simulate the force applied in response to a command.
Asked by chapulina on 2021-01-04 20:07:25 UTC
