Create a sim environnement for CNC router
asked 2021-01-07 10:12:52 -0500
dev4all12358 gravatar image
updated 2021-01-09 11:25:49 -0500
Hello, I already program on ROS but I want to create a 3D simulation of CNC rooter.
Where should I start? Is there example which could be use as base for my project?
My goal is to be able to create path planning and check collisions according to the material on the simulation
My current configuration: ROS1 ROS version :Melodic
Edit : I use a tuturial to start: https://www.youtube.com/watch?v=8ckSl...
Here is the code I made to start and generate a "floating camera": https://github.com/arnauddomes/floati...
I try to generate a simple camera that I will move. In gazebo the camera is here but it is moving and is not static.
How can I fix it?
answered 2021-01-11 09:08:09 -0500
you have the camera set to "static" https://github.com/arnauddomes/floati...
try removing that line. I would recommend the ConstructSim for tutorials, as well as the official gazebo onces.
Thank you I will try this
dev4all12358 gravatar imagedev4all12358 ( 2021-01-21 02:14:17 -0500 )edit
Asked: 2021-01-07 10:12:52 -0500
Seen: 109 times
Last updated: Jan 11 '21
