Keep Getting "Error Code: 11 Msg: Unable to find uri[model://bin]" When Running Gazebo
I am typing the Linux command, gazebo aisle.world
to try and start a gazebo simulation world. Gazebo doesn't open, but instead outputs the following error:
Below is a snippet of my aisle.world
file where I think the error is coming from
<name>bin_1</name>
<pose>-1.0 -1.5 0.5 0 0 3.1415</pose>
<uri>model://bin</uri>
<model name="bin_1_tag">
<pose>-1.0 -1.6875 0.63 0 0 3.1415</pose>
<geometry><box><size>0.2 0.01 0.2</size></box></geometry>
<script>
<uri>model://bin/tags</uri>
<!--<uri>model://bin/materials/textures</uri>-->
<name>product_1</name>
</script>
I think the issue is something with the 4th line: <uri>model://bin</uri>
. The bin directory it is referring to is located in ~/ws/src/stockroom_bot/worlds
. This directory holds a model.config
file (shown below) as well as my model.sdf
file.
<?xml version="1.0"?>
<model>
<name>Bin</name>
<sdf version="1.4">model.sdf</sdf>
I've also added the below code to my ./bashrc
file. This way I can just type sb
and it should source my .bash
file and allow my code to reference my stockroom_bot
package.
alias sb='source ~/ws/devel/setup.bash; \
export GAZEBO_MODEL_PATH=${HOME}/ws/src/stockroom_bot'
Any other guidance as to why my code can't seem to find my model.sdf
file will be much appreciated.
Linux 5.3.0-62-generic #56 18.04.1-Ubuntu
Asked by BesterJester on 2021-01-18 07:13:41 UTC
hello, I am having the same problem. Have you found any answer?
Asked by TheClem on 2021-02-21 13:16:06 UTC
Hi! I'm having the same problem. https://answers.gazebosim.org/question/27075/error-code-12-msg-unable-to-find-uri/
Asked by sudiv on 2021-06-17 02:09:55 UTC
