gazebo ardupilot plugin compilation error
Hi everyone !
I deleted gazebo, gazeboardupilot and ros for some reason I worked on before. I recently reinstalled gazebo version 9. In addition, I want to install the gazeboardupilot plugin.
cd ~
git clone https://github.com/khancyr/ardupilot_gazebo.git
cd ardupilot_gazebo
git checkout dev
I'm proceeding smoothly up to the codes above. However, when I run the code "cmake .." I get the following error.
~/ardupilot_gazebo/build$ cmake ..
CMake Error at CMakeLists.txt:11 (find_package):
  By not providing "Findgazebo.cmake" in CMAKE_MODULE_PATH this project has
  asked CMake to find a package configuration file provided by "gazebo", but
  CMake did not find one.
  Could not find a package configuration file provided by "gazebo" with any
  of the following names:
    gazeboConfig.cmake
    gazebo-config.cmake
  Add the installation prefix of "gazebo" to CMAKE_PREFIX_PATH or set
  "gazebo_DIR" to a directory containing one of the above files.  If "gazebo"
  provides a separate development package or SDK, be sure it has been
  installed.
-- Configuring incomplete, errors occurred!
See also "/home/omer/ardupilot_gazebo/build/CMakeFiles/CMakeOutput.log".
I also added the log file in case you want to look. Here you are
CmakeOutputLog
Asked by Nevez on 2021-01-19 08:48:46 UTC
you should install Gazebo dev files. sudo apt-get install libgazebo9-dev and then try again.
Regards
Asked by ahcorde on 2021-02-15 03:26:11 UTC
