How to set initial angle/position of a joint?
I noticed that the joint->initial_position was being deprecated in SDF1.8, and we were referred to use state instead. https://github.com/osrf/sdformat/issues/470
However I also noticed that state->joint->angle did not work either, we checked the source code and it seems the functionality is commented out.
This code block for loading the joint positions are commented out: ModelState.cc#L90
And also here: Model.cc#L1378
Is there any plans to restore this functionality? or could you offer an alternative method to set the initial angle of a joint inside the SDF (not using plugins) ?
Asked by cheng-kevin on 2021-01-19 16:48:25 UTC
