Using Octree in Gazebo 11
I discovered that there is a library in ROS for using octree based occupancy maps.
Is it possible to use octrees directly in gazebo? I was not able to find any tutorials for octrees in Gazebo, and I would like to know if I am wasting my time if it is not possible at all.
Thx in advance
Asked by Zeckurbo on 2021-01-24 08:59:39 UTC
Can you describe what you are trying to accomplish? In general, you can write a Gaze plugin that can be loaded at runtime. Your plugin can make use of other libraries such as octomap.
Asked by nkoenig on 2021-01-25 12:44:50 UTC
I want to use a sensor, that outputs an octomap in gazebo without publishing to a ros node first. And I also wondered if it was possible to load an octree based object into the gazebo world, like a mesh.
Asked by Zeckurbo on 2021-01-26 11:34:41 UTC
