SetWorldPose with ODE works but fails in DART
Hey guys, I have the following issue. I wrote a plugin that basically sets link poses in the world. For some reason it works when the engine is set to ode and fails when i run it using the dart engine. So when I run my world file using gazebo --verbose simulation.world the link SetWorldPose works:
I check if the correct physics engine is running, i have a print that outputs the following:
[Plugin] Using Physcis Engine: ode
Gazebo ODE Output:
(You can ignore the weird pose it is not important.)
Working with ODE
But When I run using DART, with the following command gazebo --verbose -e dart simulation.world
The print statement to check if dart is used:
[Plugin] Using Physcis Engine: dart
Gazebo DART Output
Not Working With Dart
Here you can find all the code: https://github.com/trns1997/GazeboDartTest
I just do not get why the SetWorldPose does not work when I use dart and works with ode. Hope someone can help me out with this issue.
Asked by trns1997 on 2021-01-25 13:05:18 UTC
I have found a work around. Set the root link pose and the setJointPosition did the trick. But I would still like to know why setting link pose does not work when you switch from one engine to the other.
Asked by trns1997 on 2021-01-27 08:14:34 UTC
