How to control the start of actor animation with a plugin
Hello, everyone
I'm a first time student of the Gazebo and I'm working my way through the tutorials. However, I can't get this tutorial to work (http://gazebosim.org/tutorials?tut=contain_plugin&cat=plugins).
My environment is Ubuntu 18.04 and I'm using gazebo version 9.
I found out that libContainPlugin.so is included in Ubunt 20.04. Is there any way to trigger the model in the same way on Ubuntu 18.04?
Thanks.
Asked by KKK on 2021-02-01 05:59:35 UTC
I'm on Ubuntu 18.04 and I installed gazebo9 from debians using sudo apt-get install gazebo9
. I see libContainPlugin.so
at /usr/lib/x86_64-linux-gnu/gazebo-9/plugins/libContainPlugin.so
. Can you check your system to see if it is there as well? If not, try running sudo apt-get update
followed by sudo apt-get upgrade gazebo9
Asked by nkoenig on 2021-02-02 12:22:49 UTC
