How to pass parameters to GUIPlugin for gzclient
asked 2021-02-04 10:48:43 -0600
m.bahno gravatar image
updated 2021-02-09 03:25:08 -0600
I need to run a separate node with Gazebo client like this:
<node name="gui_w_plugin" pkg="ros_gazebo" type="gzclient" args="--gui-client-plugin libgui_plugin.so"/>
However I was not able to pass any arguments to the plugin. I was also not able to find much documentation to GUIPlugin (but very brief API description).
Do you have an idea, how to:
1) pass arguments to plugin, so I can use tem in C++ plugin definition (either constructor or Load())?
2) start gazebo client other way, so I can use SDF parameters or other means?
Thank you!
answered 2021-02-11 07:18:38 -0600
In the end, I used kind of workaround to pass arguments via local ROS parameter. However, I don't think this is the best way and I would find the most elegant way to be able to specify the sdf parameters even with node call.
Asked: 2021-02-04 10:48:43 -0600
Seen: 157 times
Last updated: Feb 11 '21
