How do I run ignition gazebo distributed (server on one machine, GUI on another)?
asked 2021-02-10 17:57:01 -0500
Rick Armstrong gravatar image
I'm trying to figure out how to run ignition gazebo -s shapes.sdf on one machine, and ignition gazebo -gon another (both hosts on the same LAN). I've found the tutorial at https://ignitionrobotics.org/api/gaze..., but it's pretty terse. I tried this: ign gazebo -s --network-role=primary --network-secondaries=1 --distributed shapes.sdf, but it fails with
    2: from /usr/bin/ign:267:in `<main>'
    1: from /usr/lib/ruby/ignition/cmdgazebo3.rb:324:in `execute'
/usr/lib/ruby/ignition/cmdgazebo3.rb:310:in `parse': invalid option: --distributed (OptionParser::InvalidOption)
I'm running Citadel on Ubuntu 18.
I get the impression that the docs are a little rough. Any suggestions on where to look for more documentation or examples?
Bump. Has nobody tried this?
Rick Armstrong gravatar imageRick Armstrong ( 2021-10-25 23:33:44 -0500 )edit
Oh dear, is this still ongoing? Any luck?
kakcalu13 gravatar imagekakcalu13 ( 2022-02-18 10:48:17 -0500 )edit
answered 2023-03-19 12:47:09 -0500
civcode gravatar image
Had the same problem and landed here googling for a solution. Eventually I found out that you have to set an environment variable to tell the GUI which host and user to connect to.
See Gazebo environment variables.
My Setup:
  • Gazebo Fortress
  • The simulation is running on machine 1, the GUI is running on machine 2.
  • Both machines are in the same subnet (192.168.0.xyz).
Machine 1 (simulation):
  • user: user1
  • hostname: host1
Machine 2 (GUI):
  • user: user2
  • hostname: host2
Start the simulation on machine 1:
  • $ ign gazebo -v 4 shapes.sdf -s
Set environment variable and start GUI on machine 2:
  • $ export IGN_PARTITION=host1:user1
  • $ ign gazebo -v 4 -g
The default setting for UDS multicast works for me (see IGN_DISCOVERY_MULTICAST_IP).
Hope that helps!
Asked: 2021-02-10 17:57:01 -0500
Seen: 484 times
Last updated: Mar 19 '23
