How to write ros_ign_bridge in launch file?
asked 2021-02-13 23:35:14 -0500
I use ros2 and ignition to simulate the dynamics of bipedal robot. Thus I need to run bunch of ros_ign_bridge nodes. it is really cumbersome to run those nodes from the terminal. I want to make the launch file to run those nodes. However, I do not know what /TOPIC@ROS_MSG@IGN_MSG is. Probably it is not a parameter neither argument of the node.
Please let me know how to write launch file for the ros_ign_bridge.
ROS2:foxy
ignition: Citadel
OS: Ubuntu 20.04.2 LTS Focal Fossa
Thanks
answered 2021-02-15 02:57:20 -0500
ahcorde gravatar image
To give you an example: /chatter@std_msgs/String@ignition.msgs.StringMsg
  • chatter is the ignition topic name. This topic will be created in the ROS 2 network with the same name
  • std_msgs/String ROS type msgs
  • ignition.msgs.StringMsg: Ignition type msgs
If you want to create a launch file, you have a look to this launch file. The key part:
# Bridge
bridge = Node(
    package='ros_ign_bridge',
    executable='parameter_bridge',
    arguments=['/model/vehicle_blue/cmd_vel@geometry_msgs/msg/Twist@ignition.msgs.Twist',
               '/model/vehicle_blue/battery/linear_battery/state@sensor_msgs/msg/BatteryState@ignition.msgs.BatteryState'],
    output='screen'
Hope this help
If anyone is looking for examples with ros1 xml syntax, see https://github.com/ignitionrobotics/r...
nealtanner gravatar imagenealtanner ( 2021-10-21 11:20:46 -0500 )edit
Asked: 2021-02-13 23:35:14 -0500
Seen: 249 times
Last updated: Feb 15 '21
