What do I need to get started with a simple simulation as a beginner?
I need to simulate a simple drone and be able to give commands in flight and also get the real time sensor data. I tried using gazebo9 with ros-melodic and then found hector_quadrotor. I tried using it and then a bunch of errors popped up. One of which was that gazebo/math is not found. I searched online and found that it has been deprecated since gazebo8.
Please suggest a way to get this to work or another setup that is working for you.
Asked by cyrign on 2021-02-17 02:08:24 UTC
