Unable to find uri[model://my1stmodel]
I have a problem visualizing my custom model in Gazebo using ROS. The model is working fine if I manually add it by adding a path and dragging it from the model's tab.
To reproduce the problem step by step (using theconstructsim tutorial here, I created a simple rospack just to visualize the custom model. The directory looks like:
├── CMakeLists.txt
├── package.xml
├── launch
│   └── my_world.launch
├── models
│   └── my1stmodel
│       ├── model.config
│       └── model.sdf
└── world
    └── empty_world.world
In the launch file:
<?xml version="1.0" encoding="UTF-8" ?>
<launch>
        <!-- overwriting these args -->
        <arg name="debug" default="false" />
        <arg name="gui" default="true" />
        <arg name="pause" default="false" />
        <arg name="world" default="$(find test_simulations)/world/empty_world.world" />
        <!-- include gazebo_ros launcher -->
                <arg name="world_name" value="$(arg world)" />
                <arg name="debug" value="$(arg debug)" />
                <arg name="gui" value="$(arg gui)" />
                <arg name="paused" value="$(arg pause)" />
                <arg name="use_sim_time" value="true" />
</launch>
The model.config file:
<?xml version="1.0"?>
<model>
  <name>My first model</name>
  <version>1.0</version>
  <sdf version="1.5">model.sdf</sdf>
  <author>
    <name>Your name</name>
    <email>your@email.com</email>
  </author>
  <description>
    My first model for gazebo
  </description>
And finally the model.sdf file:
<?xml version="1.0" ?>
<sdf version="1.5">
  <model name="my1stmodel">
    <static>false</static>
            <size>3 2 5</size>
          </gox>
        <surface>
          <friction>
            <ode>
              <mu>100</mu>
              <mu2>50</mu2>
            </ode>
          </friction>
        </surface>
            <size>3 2 5</size>
          </gox>
          <script>
            <name>Gazebo/Grey</name>
          </script>
However, I cannot visualize the model and I get Unable to find uri[model://my1stmodel] when I call the launch file. After a deep search the whole day, I saw that export GAZEBO_MODEL_PATH=[...]/models:$GAZEBO_MODEL_PATH might have been added. I tried and didn't work. Then I've found people saying this shouldn't work for Gazebo on ROS.
Then I tried adding manually, like adding the path to the models tab and dragging from there, and then saving the world (with save as). I was hoping to see that I missed some folder or name error while calling the model. What I see is that the Gazebo-exported world has also added my custom model in the same way. So, I am solutionless at the moment. I can see that I cannot call the model properly but I don't see where I am wrong.
Thank you in advance
Asked by TheClem on 2021-02-21 12:22:27 UTC
