translate Velodyne LiDAR plugin code to ros2
Hi I want to translate the Velodyne LiDAR plugin script from ros1 to ros2.: http://gazebosim.org/tutorials?cat=guided_i&tut=guided_i6 there is three blocks of code which are added to plugin code to create a node and a topic and subscribe to it:
block1:
private: std::unique_ptr<ros::NodeHandle> rosNode;
private: ros::Subscriber rosSub;
private: ros::CallbackQueue rosQueue;
private: std::thread rosQueueThread;
block2:
// Initialize ros, if it has not already bee initialized.
if (!ros::isInitialized())
int argc = 0;
char **argv = NULL;
ros::init(argc, argv, "gazebo_client",
ros::init_options::NoSigintHandler);
// Create our ROS node. This acts in a similar manner to
// the Gazebo node
this->rosNode.reset(new ros::NodeHandle("gazebo_client"));
// Create a named topic, and subscribe to it.
ros::SubscribeOptions so =
ros::SubscribeOptions::create<std_msgs::Float32>(
"/" + this->model->GetName() + "/vel_cmd",
1,
boost::bind(&VelodynePlugin::OnRosMsg, this, _1),
ros::VoidPtr(), &this->rosQueue);
this->rosSub = this->rosNode->subscribe(so);
// Spin up the queue helper thread.
this->rosQueueThread =
std::thread(std::bind(&VelodynePlugin::QueueThread, this));
block3:
public: void OnRosMsg(const std_msgs::Float32ConstPtr &_msg)
this->SetVelocity(_msg->data);
/// \brief ROS helper function that processes messages
private: void QueueThread()
static const double timeout = 0.01;
while (this->rosNode->ok())
this->rosQueue.callAvailable(ros::WallDuration(timeout));
i have tried common methods which are used to create a ros2 node but i get many errors like other people: https://answers.gazebosim.org//question/24340/ros-eloquent-gazebo10-integration/ https://www.reddit.com/r/ROS/comments/f5xrq7/ros2_subscriber_node_in_a_gazebo_plugin_error/
I really appreciate any help to solve this problem.
Asked by amin_a on 2021-02-24 07:12:47 UTC
