No covariance values for imu sensor plugin libgazebo_ros_imu_sensor.so
is there any way to set covariance values for the imu plugin? I am using it to stabilize my wheel odometry using robot_localization and it complains about the imu message having no values in its covariance data and sets it to something very small.
Since i want to use some noise i would like to adjust the covariance matrix accordingly. Or do i have to switch to the hector imu plugin?
I would be thankful for any tips regrading this.
Asked by Tristan9497 on 2021-03-01 10:20:53 UTC
Looking at the source code there is not. It seems you'll ether have to recompile the source code, or write a node to take in IMU data and add your own covariance values (that's what I'm doing).
Asked by Austin on 2022-08-15 07:28:49 UTC
