ign gazebo collada meshes issue
asked 2021-03-18 12:50:24 -0500
Filipe Almeida gravatar image
I'm trying to spawn a model with dae texture files and they don't load correctly in the GzScene3D. If you look the camera plugin, the texture was loaded well, but in the scene it is a mess. I tried to use models from fuel, but all that have dae texture cause the same problem.
I'm using Ignition Citadel.
image description
Any pointers where to find a solution are highly appreciated.
tweaking some parameters in the Colladaloader file may help, not sure though.
Adwait gravatar imageAdwait ( 2021-04-01 05:08:49 -0500 )edit
I don't know how I can change that parameters. I tried different versions and different computers and got the same issue.
Filipe Almeida gravatar imageFilipe Almeida ( 2021-04-05 04:12:16 -0500 )edit
Trying on different machines won't necessarily solve the issue when there's a problem with the .dae file. What I am trying to say is that try scaling your file in the blender or any other app.
Adwait gravatar imageAdwait ( 2021-04-05 16:25:29 -0500 )edit
Right, but I did not use the same mesh in the tests. I tried different models from fuel (models that was demonstrated in the tutorials). I tested with many models from fuel and all that use collada meshes have the same issue. This is not related with my collada mesh.
Filipe Almeida gravatar imageFilipe Almeida ( 2021-04-06 04:34:26 -0500 )edit
Did you solve the problem? I think that I have the same problem, if I see in ogre2.og say and error about textures
olmer gravatar imageolmer ( 2021-05-17 16:49:48 -0500 )edit
2
answered 2021-05-17 17:47:04 -0500
I solve the problem, I added export LC_NUMERIC="C" before to run ign gazebo.
The problem is described here
I was facing the same issue with some models like this. I tried exporting this and it worked for me. Thanks.
Adwait gravatar imageAdwait ( 2021-05-21 11:00:18 -0500 )edit
Thank you!!!! It solve that problem!!! Now is loading collada meshes without that issue!
Filipe Almeida gravatar imageFilipe Almeida ( 2021-05-25 03:07:38 -0500 )edit
Asked: 2021-03-18 12:50:24 -0500
Seen: 252 times
Last updated: Mar 18 '21
