How to implement a passive caster wheel
Hello!
I’m building a diff drive robot with a passive caster-wheel that has to navigate close to obstacles. Switching from forward to backwards movement leads to a well visible wiggle movement of our robot and we would like to integrate this effect into our simulation to see if and how we have to adapt our trajectory. All robots I have seen so far use a simple sphere as caster wheel and don’t simulate the wiggle effect.
Is there a robot-description that already implements such a caster wheel?
Asked by NikolasE on 2021-03-23 03:54:49 UTC
These are older differential drive models - but they have the 2 joint caster wheel mechanism you are looking for. The joint friction/damping probably needs to be tuned to your application.
https://github.com/metamorph-inc/drivebot_models/tree/master/drivebot_description/urdf
Asked by josephcoombe on 2021-03-30 18:24:49 UTC
