How to integrate a bullet physics engine with an ode
Currently, I am in a situation where one of my sensors performs better when using bullet engine. When used under ode the Real Time Factor sinks to 0.05.
I would like to have this sensor in another simulation. However, that simulation seems to only work with ode, otherwise, it would show:
[Err] [BulletHingeJoint.cc:356] Joint must be created before getting low stop
[Err] [BulletHingeJoint.cc:345] Joint must be created before getting upper limit
[Err] [BulletHingeJoint.cc:442] Joint must be created before getting friction
This same simulation uses gazebo_ros_control, gazebo_ros_skid_steer_drive, and a Velodyne. (I don't know if any of those plugins makes the use of bullet engine impeditive).
My question is maybe how to integrate both worlds, bullet and ode. Or whether I should try to improve the sensors plugin to actually work with ode physics.
Asked by igricart on 2021-03-26 04:33:21 UTC
