plugin for actor to follow particular trajectory
asked 2021-03-30 12:46:45 -0500
updated 2021-03-31 00:17:38 -0500
By referring to this file ActorPlugin.hh in Gazebo, I am trying to migrate this into ignition gazebo using ROS for my application.
OS/Environment: Ubuntu 18.04 LTS (Installed on MacOSX using Virtual Machine)
Source/binary: Ignition-4 (binary files)
Unfortunately, my header file (code is given below) throws some syntax error.
Error:
<source-file, line>: error: ‘std::chrono::steady_clock’ has not been declared
Code:
#include <string>
#include <fstream>
#include <queue>
#include <vector>
#include <chrono>
#include <ignition/math/Pose3.hh>
#include <ignition/math/Quaternion.hh>
#include <ignition/math/Vector3.hh>
#include <ros/ros.h>
#include <ros/package.h>
#include <ros/callback_queue.h>
#include <std_msgs/String.h>
#include <ignition/gazebo/Model.hh>
#include <ignition/gazebo/EntityComponentManager.hh>
#include <ignition/gazebo/Util.hh>
#include <ignition/gazebo/System.hh>
#include <ignition/gazebo/components/Physics.hh>
#include <ignition/plugin/Register.hh>
#include <ignition/transport/Node.hh>
#include "igniton/common/Plugin.hh"
#include "dart/simulation/World.hpp"
namespace igniton
namespace gazebo
namespace systems
    class IGNITION_GAZEBO_VISIBLE ignGazeboPathFollowerRosActor:
            public ignition::gazebo::System,
            public ignition::gazebo::ISystemConfigure,
            public ignition::gazebo::ISystemPostUpdate,
            public ignition::gazebo::ISystemPreUpdate
        /// \brief Constructor
        public: ignGazeboPathFollowRosActor();
        ///  \brief Destructor
        public: ~ignGazeboPathFollowRosActor();
        // Implement Configure callback, provided by ISystemConfigure
        // and called once at startup.
        public: void Configure(const Entity & _entity,
          const std::shared_ptr <
            const sdf::Element > & _sdf,
              EntityComponentManager & _ecm,
              EventManager & /*_eventMgr*/ );
        // Documentation inherite
        public: void PreUpdate(const ignition::gazebo::UpdateInfo &_info,
                  ignition::gazebo::EntityComponentManager &_ecm);
        public: void PostUpdate(const ignition::gazebo::UpdateInfo &_info,
                   const ignition::gazebo::EntityComponentManager &_ecm);
        /// \function to reset
        public: virtual void Reset();
        /// \brief callback for updating the activation of the actor
        private: void OnActive(const std_msgs::String::ConstPtr& msg);
        private: void QueueThread();
        private: void ReadTrajectoryFile();
        private: ros::NodeHandle * ros_node_;
        private: ros::Subscriber state_sub_;
        /// \brief Custom Callback Queue
        private: ros::CallbackQueue queue_;
        /// \brief Custom Callback Queue thread
        private: boost::thread callbackQueueThread_;
        /// \brief Pointer to the parent actor
        private: ignition::gazebo::Entity actor_entity;
        /// \brief Pointer to the world
        private: std::vector<dart::simulation::WorldPtr> world;
        /// \brief pointer to the sdf element
        private: std::shared_ptr< const sdf::Element> &_sdf;
        /// \brief Reference velocity of the actor
        private: ignition::math::Vector3d ref_velocity_;
        /// \brief Time scaling factor. Used to coordinate translational motion
        /// with the actor's walking animation.
        private: double animation_factor_;
        /// \Connecting the entity
        private: ignition::gazebo::Entity entity{ignition::gazebo::kNullEntity};
        private: ignition::gazebo::Entity modelLink{ignition::gazebo::kNullEntity};
        /// \brief Time of the last update.
        private: std::chrono::steady_clock::duration last_update
        /// \brief Time of start.
        private: std::chrono::time_point start_time_;
        /// \brief Custom trajectory info.
        private: physics::TrajectoryInfoPtr trajectoryInfo;
        /// \brief Variable for control the non-constant velocity.
        private: bool oscillation_enable_;
        /// \brief To make the actor to have non-constant velocity.
        private: double oscillation_factor_;
        private: std::string active_topic_;
        private: std::string actor_state_;
        private: std::string traj_file_name_;
        /// \brief Data structure for saving the trajectory read from file
        private: std::queue<ignition::math::Pose3d>trajectory_;
#endif
Additional Context
I need some help with finding equivalent class/member functions for the following in the ignition gazebo
   private: common::Time last_update;
  private: common::Time start_time_;
  private: physics::WorldPtr world;
  private: std::queue<ignition::math::Pose3d> trajectory_;
Can you update your question with the actual console output/error
josephcoombe gravatar imagejosephcoombe ( 2021-03-30 18:26:30 -0500 )edit
I have updated the question.
Adwait gravatar imageAdwait ( 2021-03-31 00:07:43 -0500 )edit
answered 2021-04-02 13:15:14 -0500
bach gravatar image
Try to have a look to this plugin. You can define a trajectory by waypoints. It works quite well for me.
Asked: 2021-03-30 12:46:45 -0500
Seen: 232 times
Last updated: Mar 31 '21
