How to loading model XML from ros parameter like robot_description in ROS2
asked 2021-04-12 07:29:14 -0500
Hi, there. I encountered a problem, I don’t know how to load xacro file into gazebo in ros2
In ROS1, we could load model XML from ros parameter
<param name="robot_description" command="$(find xacro)/xacro --inorder '$(find m_bot_description)/urdf/mbot_gazebo.xacro'"/>
<node name="urdf_spawner" pkg="gazebo_ros" type="spawn_model" respawn="false" output="screen" args="-urdf -model mrobot -param robot_description"/>
And in ROS2, I've found that the ros2 launch have already supported the command, maybe I guess the launch file could be written as
image description
I hope there is an option something like -param in the code where I type -???, but I only found -file, -topic, -stdin in the spawn_entity.py to load the xml
How could I modify it to load the xacro file?
Thanks in advance!
answered 2021-04-19 12:32:31 -0500
Jose Luis Rivero gravatar image
updated 2021-04-20 13:04:12 -0500
That is a good question:
Looking into the examples, all I can say is that seems like the new approach is using a topic named robot_descriptionto load xacro code. See https://github.com/ros-simulation/gaz.... I can not find any other code using parameters.
To complete the information I've updated the gazebo_ros_pkgs migration wiki https://github.com/ros-simulation/gaz...
Hope it helps.
Thanks very much
Jony gravatar imageJony ( 2021-04-19 21:14:22 -0500 )edit
Asked: 2021-04-12 07:29:14 -0500
Seen: 1,775 times
Last updated: Apr 20 '21
