error: cannot convert ‘ignition::gazebo::v3::components::Component<std::vector<double> to ‘float’
asked 2021-04-14 18:25:29 -0500
updated 2021-04-14 18:29:00 -0500
I am trying to get the joint's position for my Cessna plugin using this method
float rudder =  _ecm.Component<components::JointPosition>(this->joint[5.0]);
which gives me this error in the line shown above
 error: cannot convert ‘ignition::gazebo::v3::components::Component<std::vector<double>, ignition::gazebo::v3::components::JointPositionTag, ignition::gazebo::v3::serializers::VectorDoubleSerializer>*’ to ‘float’ in initialization
     float rightFlap =  _ecm.Component<components::JointPosition>(this->joint[3.0]);
code snippet
    void CessnaPlugin::PublishState(EntityComponentManager &_ecm)
        IGN_PROFILE("CessnaPlugin::PublishState");
        // Read current state
        double propellerRpms = _ecm.ComponentData<components::JointVelocity>(this->joint[6.0])/(2.0*M_PI)*60.0;
        float propellerSpeed = propellerRpms / this->propellerMaxRpm;
        float leftAileron = _ecm.Component<components::JointPosition>(this->joint[2500]);
        float leftFlap =  _ecm.Component<components::JointPosition>(this->joint[1.0]);
        float rightAileron =  _ecm.Component<components::JointPosition>(this->joint[2.0]);
        float elevators =  _ecm.Component<components::JointPosition>(this->joint[4.0]);
        float rudder =  _ecm.Component<components::JointPosition>(this->joint[5.0]); ----> error occurs here
joint entity as declared
std::array<ignition::gazebo::Entity, 7> joint;
parameters
   private: static const unsigned int kLeftAileron  = 0;
    private: static const unsigned int kLeftFlap     = 1;
    private: static const unsigned int kRightAileron = 2;
   private: static const unsigned int kRightFlap    = 3;
    private: static const unsigned int kElevators    = 4;
    private: static const unsigned int kRudder       = 5;
    private: static const unsigned int kPropeller    = 6;
Any solution for this?
Thanks
answered 2021-04-16 06:19:39 -0500
updated 2021-04-16 06:24:20 -0500
refer this issue.
Thanks to Diego Ferigo for this answer.
A joint in its most generic form can have more than one degree of freedom. This is the reason why the JointPosition component stores a vector:
ign-gazebo/include/ignition/gazebo/components/JointPosition.hh
Lines 38 to 39 in a41cf80
 using JointPosition = Component<std::vector<double>, class JointPositionTag,
                                 serializers::VectorDoubleSerializer>;
In 99% of cases, you're using either a revolute or prismatic joint, therefore the vector contains only one element:
const auto& jointPosition = _ecm.ComponentData<components::JointVelocity>(jointEntity);
assert(jointPosition.size() == 1);
const double position = jointPosition[0];
Asked: 2021-04-14 18:25:29 -0500
Seen: 92 times
Last updated: Apr 16 '21
