Gazeobo simulator questions
I am setting the joint using the Model Editor, but I have set the axis of rotation and speed. However, when you exit the Editor and run the Simulator, the part set as a joint must rotate, but a phenomenon that does not rotate occurs. I would like to know the cause and solution for this. With gazebo's model editor, I would like to ask if it is impossible to set up a robot such as pan/tilt or robot arm to give rotation to the joints you want.
Asked by asdasd1 on 2021-04-15 00:13:30 UTC
somehow the image was not attached correctly, could you please try to fix it?
Asked by Jose Luis Rivero on 2021-04-19 11:57:17 UTC
