Why does my rviz have no odom in fixed frame?
I'm using ros2 to run gazebo-11 and rviz2
In my fixed frame
have no odom but only the links that I was defined in urdf file. What should i do to have odom in Fixed Frame
Here is my configuration of libgazeborosdiff_drive.so in urdf file
<gazebo>
<plugin name="differential_drive_controller"
filename="libgazebo_ros_diff_drive.so">
<ros>
<!-- Set namespace -->
<namespace>/</namespace>
<!-- Remap default topics -->
<argument>--ros-args --remap cmd_vel:=cmd_vel</argument>
<argument>--ros-args --remap odom:=odom</argument>
<update_rate>10.0</update_rate>
</ros>
<left_joint>left_wheel_joint</left_joint>
<right_joint>right_wheel_joint</right_joint>
<rosDebugLevel>Debug</rosDebugLevel>
<publish_wheel_TF>true</publish_wheel_TF>
<publish_tf>1</publish_tf>
<always_on>true</always_on>
<update_rate>100.0</update_rate>
<legacy_mode>true</legacy_mode>
<publish_odom>true</publish_odom>
<wheel_separation>${wheel_joint_y*2}</wheel_separation>
<wheel_diameter>${2*wheel_radius}</wheel_diameter>
<broadcast_TF>1</broadcast_TF>
<max_wheel_torque>30</max_wheel_torque>
<max_wheel_acceleration>1.8</max_wheel_acceleration>
<odometry_frame>odom</odometry_frame>
<robot_base_frame>base_footprint</robot_base_frame>
<plugin name="gazebo_ros_joint_state_publisher"
filename="libgazebo_ros_joint_state_publisher.so">
<ros>
<argument>--ros-args --remap joint_states:=joint_states</argument>
</ros>
<update_rate>100</update_rate>
<joint_name>left_wheel_joint</joint_name>
<joint_name>right_wheel_joint</joint_name>
Asked by Jony on 2021-04-19 02:43:36 UTC
Hmm...try change this line
to
<robot_base_frame>base_link</robot_base_frame>
Asked by kakcalu13 on 2021-08-17 18:44:57 UTC
