Windows Installation Error: The C compiler is not able to compile a simple test program windows
asked 2021-04-20 09:13:01 -0500
Hello, I'm trying to install Gazebo on my Windows 10 machine and I'm following the official tutorial (http://gazebosim.org/tutorials?tut=in...). When I try to configure and build the dependencies I get the following error:
image description image description
It's clear that it's caused by CMake, but I couldn't find out the problem Any idea on how to fix it? Many thanks in advance.
answered 2021-04-20 11:49:57 -0500
Jose Luis Rivero gravatar image
Not sure if the real problems is the use of x86_x64instead of x86_amd64, is the only thing that catch my attention from that log.
As an alternative, I would recommend exploring the new options of installing Gazebo driven by different community members and detailed here https://github.com/osrf/gazebo/issues.... Particularly the conda-forge installation is most active one.
I followed the conda-forge installation and I executed the two commands successfully, but there are no instructions on how to run Gazebo after installation, simply typing "gazebo" on the cmd terminal does not run it
Abdo_Ameen gravatar imageAbdo_Ameen ( 2021-04-21 04:30:01 -0500 )edit
You probably need to call it from the "Anaconda prompt" see https://docs.anaconda.com/anaconda/us...
Jose Luis Rivero gravatar imageJose Luis Rivero ( 2021-04-21 05:02:39 -0500 )edit
it does not run using Anaconda prompt neither ("gazebo" is not recognized as internal or external command, operable program or batch file.)
Abdo_Ameen gravatar imageAbdo_Ameen ( 2021-04-21 05:37:33 -0500 )edit
Jose Luis Rivero gravatar imageJose Luis Rivero ( 2021-04-21 11:39:30 -0500 )edit
yes, in another way, simply by installing ROS, and I got Gazebo included by default. Thank you for your help Mr. Rivero
Abdo_Ameen gravatar imageAbdo_Ameen ( 2021-04-22 06:43:51 -0500 )edit
Asked: 2021-04-20 09:13:01 -0500
Seen: 239 times
Last updated: Apr 20 '21
