Robot simulation is not working with DEM (elevation) on Gazebo
I am using gazebo 9.0.0 on ubuntu 18.04LTS with ROS melodic. I have created a Digital Elevation Map and created a model to load it on gazebo. So far, this worked. After this, I tried to spawn a robot in the simulated world, and the physics engine seems to not be working. On plain zones of the terrain, the simulation works. However, when the map has some kind of irregularity, the robot just floats in the air:
image description
Here is my mode.sdf file:
  <?xml version="1.0" ?>
<sdf version="1.5">
      <uri>model://sun</uri>
     <model name="heightmap">
            <heightmap>
              <uri>model://sogrape/materials/textures/elevation_129.tif</uri>
              <size>40 60 30</size>
              <pos>0 0 0</pos>
            </heightmap>
        <visual name="visual_abcedf">
            <heightmap>
              <use_terrain_paging>false</use_terrain_paging>
              <texture>
                <diffuse>file://media/materials/textures/dirt_diffusespecular.png</diffuse>
                <normal>file://media/materials/textures/flat_normal.png</normal>
                <size>1</size>
              </texture>
              <texture>
                <diffuse>file://media/materials/textures/grass_diffusespecular.png</diffuse>
                <size>1</size>
              </texture>
              <texture>
                <diffuse>file://media/materials/textures/fungus_diffusespecular.png</diffuse>
                <size>1</size>
              </texture>
              <blend>
                <min_height>2</min_height>
                <fade_dist>5</fade_dist>
              </blend>
              <blend>
                <min_height>4</min_height>
              </blend>
              <pos>0 0 0</pos>
            </heightmap>
    <physics type='bullet'>
      <max_step_size>0.01</max_step_size>
      <real_time_update_rate>0</real_time_update_rate>
      <gravity>0 0 -9.9</gravity>
    </physics>
I have tried to change the physics (from ode to bullet and simbody) system without success. What else can I do?
Asked by luis.c.santos on 2021-04-22 06:38:13 UTC
Hi did you already find a solution for this problem?
Asked by Hawkinator on 2021-10-05 08:26:53 UTC
