can't build gazebo_ros2_control after building ros2_control
ros2_control is installed and built but gazeboros2control fails:
:~/wsROS2/gazeboros2_control$ colcon build
Starting >>> gazebo_ros2_control
--- stderr: gazebo_ros2_control
CMake Error at CMakeLists.txt:6 (find_package):
By not providing "Findcontroller_manager.cmake" in CMAKE_MODULE_PATH this
project has asked CMake to find a package configuration file provided by
"controller_manager", but CMake did not find one.
Could not find a package configuration file provided by
"controller_manager" with any of the following names:
controller_managerConfig.cmake
controller_manager-config.cmake
Add the installation prefix of "controller_manager" to CMAKE_PREFIX_PATH or
set "controller_manager_DIR" to a directory containing one of the above
files. If "controller_manager" provides a separate development package or
SDK, be sure it has been installed.
Failed <<< gazebo_ros2_control [3.39s, exited with code 1]
Summary: 0 packages finished [3.52s]
1 package failed: gazebo_ros2_control
1 package had stderr output: gazebo_ros2_control
1 package not processed
What else to try?
Asked by user21307 on 2021-04-29 06:58:35 UTC
Which packages do you have installed in your system or in your workspace? controller-manager should appear in a colcon list on the workspace or you will need to install it as a binary package.
Asked by Jose Luis Rivero on 2021-05-03 10:27:25 UTC
