Unable to locate package libignition-physics-dev
Hi!
I am following the installation tutorial on: https://ignitionrobotics.org/api/physics/1.2/installation.html
but when I get to the command: sudo apt-get install libignition-physics-dev
I get the following error: E: Unable to locate package libignition-physics-dev
All the earlier commands execute without problems.
I am running Ubuntu 20.04.2 LTS and Gazebo 11.5
The reason I want to run this installation process is that I have an older version of the package "ignition-common3-graphics" that I need to upgrade: Could not find a configuration file for package "ignition-common3-graphics" that exactly matches requested version "3.13.1".
I have version 3.11.1.
Thank you
Asked by Martiasv on 2021-05-07 06:07:15 UTC
Excuse me, I don't fully understand your final goal? Are you interested in a particular version of ign-common? installing ign-physics? or the final goal is to install a different software?
Asked by Jose Luis Rivero on 2021-05-07 12:43:34 UTC
I have the same problem with the same system setup (Ubuntu 20.04.2 LTS and Gazebo 11.5).
Best regards.
Asked by Fenix0817 on 2021-05-11 09:32:47 UTC
libignition-physics-dev correspond to the 1.x series of ignition-physics which is currently end of life. I would recommend to use any other supported versions:
Asked by Jose Luis Rivero on 2021-05-19 11:26:19 UTC
