Object is slipping from Gripper of Panda Arm
I am working on a pick and place task using the Frankia Panda Arm with Effort Joint Controllers for the Arm Links as well as for the Gripper links.
The issue I am facing is related to the slipping of the object box from the gripper when the robot is picking the object.
Files:
<?xml version='1.0' encoding='utf-8'?>
<robot xmlns:xacro="http://www.ros.org/wiki/xacro" name="panda">
<gazebo reference="${ns}_hand">
<material>Gazebo/White</material>
<gazebo reference="${ns}_leftfinger">
<mu1>1000</mu1>
<mu2>1000</mu2>
<kp>1000000.0</kp>
<kd>100000.0</kd>
<slip1>0</slip1>
<slip2>0</slip2>
<minDepth>0.003</minDepth>
<maxVel>0</maxVel>
<torsional>
<ode>
<coefficient>1000</coefficient>
<slip>0</slip>
</ode>
</torsional>
<gazebo reference="${ns}_rightfinger">
<mu1>1000</mu1>
<mu2>1000</mu2>
<kp>1000000.0</kp>
<kd>100000.0</kd>
<slip1>0</slip1>
<slip2>0</slip2>
<maxVel>0</maxVel>
<torsional>
<ode>
<slip>0</slip>
</ode>
</torsional>
<transmission name="${ns}_finger_joint1_trans">
<joint name="${ns}_finger_joint1">
<hardwareInterface>hardware_interface/EffortJointInterface</hardwareInterface>
<actuator name="${ns}_finger_joint1_motor">
</actuator>
</transmission>
<transmission name="${ns}_finger_joint2_trans">
<joint name="${ns}_finger_joint2">
<actuator name="${ns}_finger_joint2_motor">
</actuator>
</transmission>
</robot>
Any suggestion to solve this issue?
Videos: - 1. https://youtu.be/j_oI9l3VXGE 2. https://youtu.be/yjjB0lFknoM
Asked by robo bug on 2021-05-08 00:39:52 UTC
