How to connect my Motion planning to my gazebo model
Hello
I try to connect the moveit panda arm demo to the model I generate with setup assistant of moveit. To launch the panda arm in rviz I launch :
roslaunch panda_moveit_config demo.launch
Rviz run properly, the I use the model I generate with setup assistante in gazebo: In one terminal I run: roslaunch gazeboros emptyworld.launch paused:=true usesimtime:=false gui:=true throttled:=false recording:=false debug:=true
In other:
rosrun gazebo_ros spawn_model -file ./panda_arm.gazebo -urdf -x 0 -y 0 -z 1 -model panda
The arm is properly display but its position doesn't math with the rviz robot position. And when I plan trajectory in rviz, the arm is not moving in gazebo.
Here is the result:
Here is the modified demo.launch
<launch>
<!-- By default, we do not start a database (it can be large) -->
<arg name="db" default="false" />
<!-- Allow user to specify database location -->
<arg name="db_path" default="$(find panda_moveit_config)/default_warehouse_mongo_db" />
<!-- By default, we are not in debug mode -->
<arg name="debug" default="true" />
<arg name="pipeline" default="ompl" />
By default, hide joint_state_publisher's GUI
MoveIt!'s "demo" mode replaces the real robot driver with the joint_state_publisher.
The latter one maintains and publishes the current joint configuration of the simulated robot.
It also provides a GUI to move the simulated robot around "manually".
This corresponds to moving around the real robot without the use of MoveIt.
<arg name="rviz_tutorial" default="false" />
<arg name="use_gui" default="false" />
<!-- Load the URDF, SRDF and other .yaml configuration files on the param server -->
<include file="$(find panda_moveit_config)/launch/planning_context.launch">
<arg name="load_robot_description" value="true"/>
<arg name="initial_joint_states"
default=" -J panda::panda_joint1 0.000
-J panda::panda_joint2 0.0
-J panda::panda_joint3 0.0
-J panda::panda_joint4 0.0
-J panda::panda_joint5 0.0
-J panda::panda_joint6 0.0
-J panda::panda_joint7 0.0"/>
<arg name="world" default="empty"/>
<arg name="use_sim_time" default="true"/>
<arg name="headless" default="false"/>
<!--arg name="world_name" value="$(find mybot_gazebo)/worlds/mybot.world"/-->
<arg name="paused" value="$(arg paused)"/>
<arg name="use_sim_time" value="$(arg use_sim_time)"/>
<arg name="gui" value="$(arg gui)"/>
<arg name="headless" value="$(arg headless)"/>
<arg name="debug" value="$(arg debug)"/>
<node name="mybot_spawn" pkg="gazebo_ros" type="spawn_model" output="screen"
args="-urdf -param robot_description_semantic -model panda $(arg initial_joint_states)" />
<!-- create a tf with base frame as 'base' (to match aml_robot) -->
<node pkg="tf" type="static_transform_publisher" name="base_to_link0" args="0 0 0 0 0 0 1 base panda_link0 100" />
<node pkg="tf" type="static_transform_publisher" name="world_to_base" args="0 0 0 0 0 0 1 world base 100" />
<!-- If needed, broadcast static tf for robot root -->
<node pkg="tf2_ros" type="static_transform_publisher" name="virtual_joint_broadcaster_1" args="0 0 0 0 0 0 world panda_link0" />
<!-- We do not have a robot connected, so publish fake joint states -->
<node name="joint_state_publisher" pkg="joint_state_publisher" type="joint_state_publisher">
<param name="/use_gui" value="$(arg use_gui)"/>
<rosparam param="/source_list">[/move_group/fake_controller_joint_states]</rosparam>
</node>
<node name="joint_state_desired_publisher" pkg="topic_tools" type="relay" args="joint_states joint_states_desired" />
<!-- Given the published joint states, publish tf for the robot links -->
<node name="robot_state_publisher" pkg="robot_state_publisher" type="robot_state_publisher" respawn="true" output="screen" />
<!-- Run the main MoveIt executable without trajectory execution (we do not have controllers configured by default) -->
<include file="$(find panda_moveit_config)/launch/move_group.launch">
<arg name="allow_trajectory_execution" value="true"/>
<arg name="fake_execution" value="true"/>
<arg name="info" value="true"/>
<arg name="pipeline" value="$(arg pipeline)" />
<!-- Run Rviz -->
<include file="$(find panda_moveit_config)/launch/moveit_rviz.launch">
<arg name="rviz_tutorial" value="$(arg rviz_tutorial)"/>
<!-- If database loading was enabled, start mongodb as well -->
<include file="$(find panda_moveit_config)/launch/default_warehouse_db.launch" if="$(arg db)">
<arg name="moveit_warehouse_database_path" value="$(arg db_path)"/>
</launch>
Asked by dev4all12358 on 2021-05-18 10:42:54 UTC
