Read out actor animation skeleton node pose with plugin
Hi community,
this is less a question than an answer.
I was looking for a solution to output the pose of each armature bone for an animated <actor>.
Possible use cases could be to get the position of the hand of a human for human robot interaction.
Since I had to dig a bit deeper into the gazebo source code, I thought I would share my findings.
Here is the core part of the actor_plugin.cc:
void ActorPlugin::Load(physics::ModelPtr _model, sdf::ElementPtr _sdf)
this->actor = boost::dynamic_pointer_cast<physics::Actor>(_model);
this->connections.push_back(event::Events::ConnectWorldUpdateBegin(
std::bind(&StickPlugin::OnUpdate, this, std::placeholders::_1)));
// Initialize ros, if it has not already bee initialized.
if (!ros::isInitialized())
int argc = 0;
char **argv = NULL;
ros::init(argc, argv, "gazebo_client",
ros::init_options::NoSigintHandler);
void ActorPlugin::OnUpdate(const common::UpdateInfo &_info)
ignition::math::Pose3d pose = this->actor->WorldPose();
ROS_INFO_STREAM("Actor world Pose: " << pose.Pos().X() << ", " << pose.Pos().Y() << ", " << pose.Pos().Z());
auto skelAnims = this->actor->SkeletonAnimations();
auto folding_animation = skelAnims.find("animation_name");
if (folding_animation == skelAnims.end())
ROS_ERROR_STREAM("Skeleton animation " << "animation_name" << " not found.");
else
std::map<std::string, ignition::math::Matrix4d> node_pose = folding_animation->second->PoseAt(this->actor->ScriptTime(), true);
for (auto const& [key, val] : node_pose)
ROS_INFO_STREAM("Pose of node " << key << " is \n" <<
val(0,0) << " " << val(0,1) << " " << val(0,2) << " " << val(0,3) << "\n" <<
val(1,0) << " " << val(1,1) << " " << val(1,2) << " " << val(1,3) << "\n" <<
val(2,0) << " " << val(2,1) << " " << val(2,2) << " " << val(2,3) << "\n" <<
val(3,0) << " " << val(3,1) << " " << val(3,2) << " " << val(3,3));
Since I used the C++17 map iteration, I add add_definitions(-std=c++17) to my CMakeList.txt
You can multiply the transformation matrices to get the pose of each joint (simple forward kinematics).
I hope this might be useful for other gazeboneers.
Asked by JakobThumm on 2021-05-19 10:25:53 UTC
